[solved] Adding an new layer breaks Model 01’s firmware
After finally finding the time to apply the fixes as kindly described in this thread, I started playing around with my Model 01’s firmware again.
Then I run into the following problem, which I don’t understand:
Arduino: 1.8.19 (Linux), Board: "Keyboardio Model 01"
Model01-Firmware:313:1: error: macro "PER_KEY_DATA_STACKED" requires 66 arguments, but only 64 given
 ) // KEYMAPS(
exit status 1
also:
Invalid library found in /home/hook/.arduino15/packages/keyboardio/hardware/avr/2022.2.19183125/libraries/Kaleidoscope-LEDControl: no headers files (.h) found in /home/hook/.arduino15/packages/keyboardio/hardware/avr/2022.2.19183125/libraries/Kaleidoscope-LEDControl
Given the number, I counted the entries of keys in my newly added layer, but all the other layers also have 64 keys. So that’s not it.
This is the version that works:
And this is the commit that breaks it:
What am I doing wrong?
Managed to fix it. There was a silly typo. Fixed now in
