Can't toggle between layers
Hey there,
Thanks to the help of this community, I got my custom firmware up and running. Only issue is that I can’t switch back between my two layers, I can only switch to the second and then I’m stuck there until I reflash the firmware.
Can anyone tell me why this is happening?
I’ve got the same key on both layers set to either LockLayer(COLEMAK) or LockLayer(GAMING_QWERTY), thinking this would be enough to switch between the two but it’s not working.
Here’s my code.
// -- mode: c++ --
// Copyright 2016 Keyboardio, inc. jesse@keyboard.io
#ifndef BUILD_INFORMATION
#define BUILD_INFORMATION "locally built"
#endif
These #include directives pull in the Kaleidoscope firmware core,
as well as the Kaleidoscope plugins we use in the Model 01’s firmware
// The Kaleidoscope core
#include "Kaleidoscope.h"
// Support for macros
// Support for controlling the keyboard’s LEDs
// Support for "Numpad" mode, which is mostly just the Numpad specific LED mode
#include "Kaleidoscope-NumPad.h"
// Support for an "LED off mode"
#include "LED-Off.h"
// Support for the "Boot greeting" effect, which pulses the ‘LED’ button for 10s
// Support for LED modes that set all LEDs to a single color
// Support for an LED mode that makes all the LEDs ‘breathe’
#include "Kaleidoscope-LEDEffect-Breathe.h"
#include "Kaleidoscope-LEDEffect-Chase.h"
// Support for LED modes that pulse the keyboard’s LED in a rainbow pattern
// Support for an LED mode that prints the keys you press in letters 4px high
#include "Kaleidoscope-LED-AlphaSquare.h"
// Support for Keyboardio’s internal keyboard testing mode
#include "Kaleidoscope-Model01-TestMode.h"
/** This ‘enum’ is a list of all the macros used by the Model 01’s firmware
The names aren’t particularly important. What is important is that each
is unique.
These are the names of your macros. They’ll be used in two places.
The first is in your keymap definitions. There, you’ll use the syntax
M(MACRO_NAME) to mark a specific keymap position as triggering MACRO_NAME
The second usage is in the ‘switch’ statement in the macroAction function.
That switch statement actually runs the code associated with a macro when
a macro key is pressed.
enum { MACRO_VERSION_INFO,
MACRO_ANY
/** The Model 01’s key layouts are defined as ‘keymaps’. By default, there are three
keymaps: The standard QWERTY keymap, the "Function layer" keymap and the "Numpad"
keymap.
Each keymap is defined as a list using the ‘KEYMAP_STACKED’ macro, built
of first the left hand’s layout, followed by the right hand’s layout.
Keymaps typically consist mostly of Key_ definitions. There are many, many keys
defined as part of the USB HID Keyboard specification. You can find the names
(if not yet the explanations) for all the standard Key_ defintions offered by
Kaleidoscope in these files:
https://github.com/keyboardio/Kaleidoscope/blob/master/src/key_defs_keyboard.h
https://github.com/keyboardio/Kaleidoscope/blob/master/src/key_defs_consumerctl.h
https://github.com/keyboardio/Kaleidoscope/blob/master/src/key_defs_sysctl.h
https://github.com/keyboardio/Kaleidoscope/blob/master/src/key_defs_keymaps.h
Additional things that should be documented here include
using ___ to let keypresses fall through to the previously active layer
using XXX to mark a keyswitch as ‘blocked’ on this layer
using ShiftToLayer() and LockLayer() keys to change the active keymap.
the special nature of the PROG key
keeping NUM and FN consistent and accessible on all layers
The "keymaps" data structure is a list of the keymaps compiled into the firmware.
The order of keymaps in the list is important, as the ShiftToLayer(#) and LockLayer(#)
macros switch to key layers based on this list.
A key defined as ‘ShiftToLayer(FUNCTION)’ will switch to FUNCTION while held.
Similarly, a key defined as ‘LockLayer(NUMPAD)’ will switch to NUMPAD when tapped.
Layers are "0-indexed" – That is the first one is layer 0. The second one is layer 1.
The third one is layer 2.
This ‘enum’ lets us use names like QWERTY, FUNCTION, and NUMPAD in place of
the numbers 0, 1 and 2.
enum { COLEMAK, FUNCTION, NUMPAD, GAMING_QWERTY }; // layers
/* This comment temporarily turns off astyle’s indent enforcement
so we can make the keymaps actually resemble the physical key layout better
// INDENT-OFF
[COLEMAK] = KEYMAP_STACKED
(___, Key_1, Key_2, Key_3, Key_4, Key_5, Key_LEDEffectNext,
Key_Backtick, Key_Q, Key_W, Key_F, Key_P, Key_G, Key_Tab,
Key_PageUp, Key_A, Key_R, Key_S, Key_T, Key_D,
ShiftToLayer(FUNCTION),
M(MACRO_ANY), Key_6, Key_7, Key_8, Key_9, Key_0, Key_KeypadNumLock,
Key_Enter, Key_J, Key_L, Key_U, Key_Y, Key_Semicolon, Key_Equals,
Key_H, Key_N, Key_E, Key_I, Key_O, Key_Quote,
LockLayer(GAMING_QWERTY), Key_K, Key_M, Key_Comma, Key_Period, Key_Slash, Key_Minus,
ShiftToLayer(FUNCTION)),
[FUNCTION] = KEYMAP_STACKED
(___, Key_F1, Key_F2, Key_F3, Key_F4, Key_F5, XXX,
Key_Tab, ___, Key_mouseUp, ___, Key_mouseBtnR, Key_mouseWarpEnd, Key_mouseWarpNE,
Key_Home, Key_mouseL, Key_mouseDn, Key_mouseR, Key_mouseBtnL, Key_mouseWarpNW,
Key_End, Key_PrintScreen, Key_Insert, ___, Key_mouseBtnM, Key_mouseWarpSW, Key_mouseWarpSE,
___, Key_Delete, ___, ___,
___,
Consumer_ScanPreviousTrack, Key_F6, Key_F7, Key_F8, Key_F9, Key_F10, Key_F11,
Consumer_PlaySlashPause, Consumer_ScanNextTrack, Key_LeftCurlyBracket, Key_RightCurlyBracket, Key_LeftBracket, Key_RightBracket, Key_F12,
Key_LeftArrow, Key_DownArrow, Key_UpArrow, Key_RightArrow, ___, ___,
Key_PcApplication, Consumer_Mute, Consumer_VolumeDecrement, Consumer_VolumeIncrement, ___, Key_Backslash, Key_Pipe,
___, ___, Key_Enter, ___,
 ___),
[NUMPAD] = KEYMAP_STACKED
___, ___, ___, ___,
___,
M(MACRO_VERSION_INFO), ___, Key_Keypad7, Key_Keypad8, Key_Keypad9, Key_KeypadSubtract, ___,
___, ___, Key_Keypad4, Key_Keypad5, Key_Keypad6, Key_KeypadAdd, ___,
___, Key_Keypad1, Key_Keypad2, Key_Keypad3, Key_Equals, Key_Quote,
___, ___, Key_Keypad0, Key_KeypadDot, Key_KeypadMultiply, Key_KeypadDivide, Key_Enter,
___, ___, ___, ___,
___),
[GAMING_QWERTY] = KEYMAP_STACKED
   (Key_Escape,    Key_1, Key_2, Key_3, Key_4, Key_5, Key_T,
    Key_Backtick,  Key_Tab, Key_Q, Key_W, Key_E, Key_R, Key_G,
    Key_PageUp,    Key_LeftShift, Key_A, Key_S, Key_D, Key_F,
    Key_PageDown,  Key_LeftControl, Key_Z, Key_X, Key_C, Key_V, Key_B,
    Key_LeftControl, Key_LeftAlt, Key_Spacebar, Key_LeftShift,
    Key_Enter,      Key_Y, Key_U, Key_I,     Key_O,      Key_P,         Key_Equals,
                    Key_H, Key_J, Key_K,     Key_L,      Key_Semicolon, Key_Quote,
    LockLayer(COLEMAK),   Key_N, Key_M, Key_Comma, Key_Period, Key_Slash,     Key_Minus,
/* Re-enable astyle’s indent enforcement */
// INDENT-ON
/** versionInfoMacro handles the ‘firmware version info’ macro
When a key bound to the macro is pressed, this macro
prints out the firmware build information as virtual keystrokes
static void versionInfoMacro(uint8_t keyState) {
if (keyToggledOn(keyState)) {
Macros.type(PSTR("Keyboardio Model 01 - Kaleidoscope "));
/** anyKeyMacro is used to provide the functionality of the ‘Any’ key.
When the ‘any key’ macro is toggled on, a random alphanumeric key is
selected. While the key is held, the function generates a synthetic
keypress event repeating that randomly selected key.
static void anyKeyMacro(uint8_t keyState) {
static Key lastKey;
lastKey.keyCode = Key_A.keyCode + (uint8_t)(millis() % 36);
if (keyIsPressed(keyState))
kaleidoscope::hid::pressKey(lastKey);
switch (macroIndex) {
case MACRO_VERSION_INFO:
versionInfoMacro(keyState);
case MACRO_ANY:
anyKeyMacro(keyState);
return MACRO_NONE;
// These ‘solid’ color effect definitions define a rainbow of
// LED color modes calibrated to draw 500mA or less on the
// Keyboardio Model 01.
static kaleidoscope::LEDSolidColor solidRed(160, 0, 0);
static kaleidoscope::LEDSolidColor solidOrange(140, 70, 0);
static kaleidoscope::LEDSolidColor solidYellow(130, 100, 0);
static kaleidoscope::LEDSolidColor solidGreen(0, 160, 0);
static kaleidoscope::LEDSolidColor solidBlue(0, 70, 130);
static kaleidoscope::LEDSolidColor solidIndigo(0, 0, 170);
static kaleidoscope::LEDSolidColor solidViolet(130, 0, 120);
/** The ‘setup’ function is one of the two standard Arduino sketch functions.
It’s called when your keyboard first powers up. This is where you set up
Kaleidoscope and any plugins.
void setup() {
// First, call Kaleidoscope’s internal setup function
Kaleidoscope.setup();
// Next, tell Kaleidoscope which plugins you want to use.
// added in the order they’re listed here.
Kaleidoscope.use(
// The boot greeting effect pulses the LED button for 10 seconds after the keyboard is first connected
&BootGreetingEffect,
// The hardware test mode, which can be invoked by tapping Prog, LED and the left Fn button at the same time.
&TestMode,
&LEDControl,
&LEDOff,
// The rainbow effect changes the color of all of the keyboard's keys at the same time
&LEDRainbowEffect,
&LEDRainbowWaveEffect,
&LEDChaseEffect,
&solidRed, &solidOrange, &solidYellow, &solidGreen, &solidBlue, &solidIndigo, &solidViolet,
&LEDBreatheEffect,
// The AlphaSquare effect prints each character you type, using your
// keyboard's LEDs as a display
&AlphaSquareEffect,
&StalkerEffect,
// The numpad plugin is responsible for lighting up the 'numpad' mode
// with a custom LED effect
&NumPad,
&Macros,
&MouseKeys
NumPad.numPadLayer = NUMPAD;
AlphaSquare.color = { 255, 0, 0 };
LEDRainbowEffect.brightness(150);
LEDRainbowWaveEffect.brightness(150);
// The LED Stalker mode has a few effects. The one we like is
// called ‘BlazingTrail’. For details on other options,
// see https://github.com/keyboardio/Kaleidoscope-LED-Stalker
StalkerEffect.variant = STALKER(BlazingTrail);
// We want to make sure that the firmware starts with LED effects off
// This avoids over-taxing devices that don’t have a lot of power to share
// with USB devices
LEDOff.activate();
As you might expect, it runs in a loop, never exiting.
For Kaleidoscope-based keyboard firmware, you usually just want to
call Kaleidoscope.loop(); and not do anything custom here.
void loop() {
The issue here is that GAMING_QWERTY shadows the COLEMAK layer: LockLayer(COLEMAK) turns that layer on, but keeps GAMING_QWERTY active too, and since this latter one is the higher layer, it will remain in effect.
Change the LockLayer(COLEMAK) on the GAMING_QWERTY layer either to ___ (transparent), or LockLayer(GAMING_QWERTY), or UnlockLayer(GAMING_QWERTY). Either of these will turn the layer off, and since you have COLEMAK active too, that will become the effective layer.
In Kaleidoscope layers are not exclusive, they are layered on top of each other, and you can have many active at the same time. This is both useful - and as we see here - sometimes a bit confusing. To get back to a layer from another, you simply have to turn the second one off. Assuming that the first one is still active, but the base layer is pretty much always active, and not easy to turn off.
Changed it to UnlockLayer(GAMING_QWERTY) and it works like a charm now. Koszonom szepen!
The last time I checked, the base layer was actually impossible to turn off (without changing Kaleidoscope itself). Not that there aren’t other ways to make the keyboard inoperative — such as a top layer that’s all Key_NoKey
