Default firmware keymap == Dvorak?! Primary Keymap changing without flashing
Any help fixing this or isolating the issue to the user, firmware, keyboard, or PC would be appreciated.
Windows 10
Keyboardio 1.94.0-beta
Arduino 1.8.8 (I believe I installed several drivers e.g. USB during installation. That may have not been the right thing to do.)
I’ve been trying the following keymaps:
  • Workman
  • Dvorak (default)
  • Dvorak (modified)
For Workman and Dvorak (modified), I added
  1. a corresponding
    #elif defined (PRIMARY_KEYMAP_WORKMAN) and
    #elif defined (PRIMARY_KEYMAP_DVORAKMOD)
    keymap to the KEYMAPS() section
  2. an additional
    #define PRIMARY_KEYMAP_WORKMAN and
    #define PRIMARY_KEYMAP_DVORAKMOD
    (I made very sure to keep all but one commented out, at a time.)
As I made changes to the DVORAK, all was fine. The last thing I remember was that I moved the LED key to the function layer, verified that it worked, packed up the Keyboardio and came home. When I powered it up, this evening, the keymap was… changed. I am a novice at Dvorak (USA), but I know there shouldn’t be vowels coming from the right side of the keyboard (let’s call this new layout ‘MUTANT’). So
  • I re-flash my firmware and keymap stays MUTANT
  • I flash the ‘example’ firmware and I get DVORAK instead of QWERTY (this happened, twice)
  • About 10 minutes later, the layout spontaneously changed to MUTANT
  • And then, a few minutes later, it spontaneously changed to QWERTY
(By ‘spontaneous’ I mean ‘without me flashing it or powercycling the keyboard.’)
  • I then flashed using the example: QWERTY
  • I then modified the example to DVORAK: DVORAK
  • I then flashed using my DVORAKMOD layout: I got my DVORAKMOD
Are there any suggestions to troubleshoot this? This can’t be normal (can it?). Thanks.
Can you post your sketch?
So, it happened, again. My layout is now
`-wvlfu ijpnz
 Ar.gce dybo[
 S’htqx m,k;]
Interesting: with the LEDs set to display the letter I just pressed, the letter is still correct.
Wow: now it’s back to normal. Lasted about 10 minutes.
Note: in troubleshooting this, I changed the name of my layout from DVORAKMOD to HEATH
// -*- mode: c++ -*-
// Copyright 2016 Keyboardio, inc. <jesse@keyboard.io>
#ifndef BUILD_INFORMATION
#define BUILD_INFORMATION "locally built"
#endif
 * These #include directives pull in the Kaleidoscope firmware core,
 * as well as the Kaleidoscope plugins we use in the Model 01's firmware
// The Kaleidoscope core
#include "Kaleidoscope.h"
// Support for storing the keymap in EEPROM
#include "Kaleidoscope-EEPROM-Settings.h"
#include "Kaleidoscope-EEPROM-Keymap.h"
// Support for communicating with the host via a simple Serial protocol
#include "Kaleidoscope-FocusSerial.h"
// Support for macros
// Support for "Numpad" mode, which is mostly just the Numpad specific LED mode
#include "Kaleidoscope-NumPad.h"
// Support for the "Boot greeting" effect, which pulses the 'LED' button for 10s
// Support for LED modes that set all LEDs to a single color
// Support for an LED mode that makes all the LEDs 'breathe'
#include "Kaleidoscope-LEDEffect-Breathe.h"
#include "Kaleidoscope-LEDEffect-Chase.h"
// Support for LED modes that pulse the keyboard's LED in a rainbow pattern
// Support for an LED mode that prints the keys you press in letters 4px high
#include "Kaleidoscope-LED-AlphaSquare.h"
// Support for Keyboardio's internal keyboard testing mode
#include "Kaleidoscope-Model01-TestMode.h"
// Support for host power management (suspend & wakeup)
#include "Kaleidoscope-HostPowerManagement.h"
// Support for magic combos (key chords that trigger an action)
#include "Kaleidoscope-MagicCombo.h"
// Support for USB quirks, like changing the key state report protocol
#include "Kaleidoscope-USB-Quirks.h"
/** This 'enum' is a list of all the macros used by the Model 01's firmware
  * The names aren't particularly important. What is important is that each
  * is unique.
  * These are the names of your macros. They'll be used in two places.
  * The first is in your keymap definitions. There, you'll use the syntax
  * `M(MACRO_NAME)` to mark a specific keymap position as triggering `MACRO_NAME`
  * The second usage is in the 'switch' statement in the `macroAction` function.
  * That switch statement actually runs the code associated with a macro when
  * a macro key is pressed.
enum { MACRO_VERSION_INFO,
       MACRO_ANY
/** The Model 01's key layouts are defined as 'keymaps'. By default, there are three
  * keymaps: The standard QWERTY keymap, the "Function layer" keymap and the "Numpad"
  * keymap.
  * Each keymap is defined as a list using the 'KEYMAP_STACKED' macro, built
  * of first the left hand's layout, followed by the right hand's layout.
  * Keymaps typically consist mostly of `Key_` definitions. There are many, many keys
  * defined as part of the USB HID Keyboard specification. You can find the names
  * (if not yet the explanations) for all the standard `Key_` defintions offered by
  * Kaleidoscope in these files:
  *    https://github.com/keyboardio/Kaleidoscope/blob/master/src/key_defs_keyboard.h
  *    https://github.com/keyboardio/Kaleidoscope/blob/master/src/key_defs_consumerctl.h
  *    https://github.com/keyboardio/Kaleidoscope/blob/master/src/key_defs_sysctl.h
  *    https://github.com/keyboardio/Kaleidoscope/blob/master/src/key_defs_keymaps.h
  * Additional things that should be documented here include
  *   using ___ to let keypresses fall through to the previously active layer
  *   using XXX to mark a keyswitch as 'blocked' on this layer
  *   using ShiftToLayer() and LockLayer() keys to change the active keymap.
  *   keeping NUM and FN consistent and accessible on all layers
  * The PROG key is special, since it is how you indicate to the board that you
  * want to flash the firmware. However, it can be remapped to a regular key.
  * When the keyboard boots, it first looks to see whether the PROG key is held
  * down; if it is, it simply awaits further flashing instructions. If it is
  * not, it continues loading the rest of the firmware and the keyboard
  * functions normally, with whatever binding you have set to PROG. More detail
  * here: https://community.keyboard.io/t/how-the-prog-key-gets-you-into-the-bootloader/506/8
  * The "keymaps" data structure is a list of the keymaps compiled into the firmware.
  * The order of keymaps in the list is important, as the ShiftToLayer(#) and LockLayer(#)
  * macros switch to key layers based on this list.
  * A key defined as 'ShiftToLayer(FUNCTION)' will switch to FUNCTION while held.
  * Similarly, a key defined as 'LockLayer(NUMPAD)' will switch to NUMPAD when tapped.
  * Layers are "0-indexed" -- That is the first one is layer 0. The second one is layer 1.
  * The third one is layer 2.
  * This 'enum' lets us use names like QWERTY, FUNCTION, and NUMPAD in place of
  * the numbers 0, 1 and 2.
enum { PRIMARY, NUMPAD, FUNCTION }; // layers
  * To change your keyboard's layout from QWERTY to DVORAK or COLEMAK, comment out the line
  * #define PRIMARY_KEYMAP_QWERTY
  * by changing it to
  * // #define PRIMARY_KEYMAP_QWERTY
  * Then uncomment the line corresponding to the layout you want to use.
// #define PRIMARY_KEYMAP_COLEMAK
// #define PRIMARY_KEYMAP_DVORAK
#define PRIMARY_KEYMAP_HEATH
// #define PRIMARY_KEYMAP_CUSTOM
// #define PRIMARY_KEYMAP_WORKMAN
/* This comment temporarily turns off astyle's indent enforcement
 *   so we can make the keymaps actually resemble the physical key layout better
// *INDENT-OFF*
KEYMAPS(
#if defined (PRIMARY_KEYMAP_QWERTY)
  [PRIMARY] = KEYMAP_STACKED
  (___,          Key_1, Key_2, Key_3, Key_4, Key_5, Key_LEDEffectNext,
   Key_PageUp,   Key_A, Key_S, Key_D, Key_F, Key_G,
   ShiftToLayer(FUNCTION),
   M(MACRO_ANY),  Key_6, Key_7, Key_8,     Key_9,         Key_0,         LockLayer(NUMPAD),
   Key_Enter,     Key_Y, Key_U, Key_I,     Key_O,         Key_P,         Key_Equals,
   Key_RightAlt,  Key_N, Key_M, Key_Comma, Key_Period,    Key_Slash,     Key_Minus,
   ShiftToLayer(FUNCTION)),
#elif defined (PRIMARY_KEYMAP_DVORAK)
  Key_Backtick, Key_Quote,     Key_Comma, Key_Period, Key_P, Key_Y, Key_Tab,
  Key_PageUp,   Key_A,         Key_O,     Key_E,      Key_U, Key_I,
  Key_PageDown, Key_Semicolon, Key_Q,     Key_J,      Key_K, Key_X, Key_Escape,
  Key_Enter,      Key_F, Key_G, Key_C, Key_R, Key_L, Key_Slash,
                  Key_D, Key_H, Key_T, Key_N, Key_S, Key_Minus,
  Key_RightAlt,   Key_B, Key_M, Key_W, Key_V, Key_Z, Key_Equals,
#elif defined (PRIMARY_KEYMAP_HEATH)
  (___,          Key_1,         Key_2,     Key_3,      Key_4, Key_5, Key_Tab,
   Key_Backtick, Key_Quote,     Key_Comma, Key_Period, Key_P, Key_Y, ___,
   Key_PageDown, Key_Semicolon, Key_Q,     Key_J,      Key_K, Key_X, Key_LeftAlt,
   Key_LeftControl, Key_Backspace, Key_LeftShift, Key_Escape,
   Key_LeftGui,    Key_6, Key_7, Key_8, Key_9, Key_0, LockLayer(NUMPAD),
   ___,            Key_F, Key_G, Key_C, Key_R, Key_L, Key_Slash,
   Key_Enter, Key_RightShift, Key_Spacebar, Key_RightControl,
#elif defined (PRIMARY_KEYMAP_COLEMAK)
   Key_Backtick, Key_Q, Key_W, Key_F, Key_P, Key_G, Key_Tab,
   Key_PageUp,   Key_A, Key_R, Key_S, Key_T, Key_D,
   Key_Enter,     Key_J, Key_L, Key_U,     Key_Y,         Key_Semicolon, Key_Equals,
                  Key_H, Key_N, Key_E,     Key_I,         Key_O,         Key_Quote,
   Key_RightAlt,  Key_K, Key_M, Key_Comma, Key_Period,    Key_Slash,     Key_Minus,
#elif defined (PRIMARY_KEYMAP_CUSTOM)
  // Edit this keymap to make a custom layout
   Key_Backtick, Key_Q,       Key_D,     Key_R,      Key_W, Key_B, Key_Tab,
   Key_PageUp,   Key_A,       Key_S,     Key_H,      Key_T, Key_G,
   Key_PageDown, Key_Z,   Key_X,     Key_M,      Key_C, Key_V, Key_Escape,
   Key_LeftControl, Key_Backspace, Key_LeftShift, Key_LeftAlt,
   Key_Delete,     Key_6, Key_7, Key_8, Key_9, Key_0, Key_KeypadNumLock,
   Key_Enter,      Key_J, Key_F, Key_U, Key_P, Key_Semicolon, Key_Equals,
                   Key_Y, Key_N, Key_E, Key_O, Key_I, Key_Quote,
   Key_RightAlt,   Key_K, Key_L, Key_Comma, Key_Period, Key_Slash, Key_Minus,
   Key_RightGui, Key_RightShift, Key_Spacebar, Key_RightControl,
#else
#error "No default keymap defined. You should make sure that you have a line like '#define PRIMARY_KEYMAP_QWERTY' in your sketch"
#endif
  [NUMPAD] =  KEYMAP_STACKED
   ___, ___, ___, ___,
   ___,
   M(MACRO_VERSION_INFO),  ___, Key_Keypad7, Key_Keypad8,   Key_Keypad9,        Key_KeypadSubtract, ___,
   ___,                    ___, Key_Keypad4, Key_Keypad5,   Key_Keypad6,        Key_KeypadAdd,      ___,
                           ___, Key_Keypad1, Key_Keypad2,   Key_Keypad3,        Key_Equals,         ___,
   ___,                    ___, Key_Keypad0, Key_KeypadDot, Key_KeypadMultiply, Key_KeypadDivide,   Key_Enter,
   ___, ___, ___, ___,
   ___),
  [FUNCTION] =  KEYMAP_STACKED
  (LCTRL(LALT(Key_Delete)),      Key_F1,           Key_F2,      Key_F3,     Key_F4,        Key_F5,           Key_LEDEffectNext,//Key_CapsLock,
   Key_Tab,  ___,              Key_mouseUp, ___,        Key_mouseBtnR, Key_mouseWarpEnd, Key_mouseWarpNE,
   Key_Home, Key_mouseL,       Key_mouseDn, Key_mouseR, Key_mouseBtnL, Key_mouseWarpNW,
   Key_End,  Key_PrintScreen,  Key_Insert,  ___,        Key_mouseBtnM, Key_mouseWarpSW,  Key_mouseWarpSE,
   ___, Key_Delete, ___, ___,
   ___,
   Consumer_PlaySlashPause,    Consumer_ScanNextTrack, Key_LeftCurlyBracket,     Key_RightCurlyBracket,    Key_LeftBracket, Key_RightBracket, Key_F12,
                               Key_LeftArrow,          Key_DownArrow,            Key_UpArrow,              Key_RightArrow,  ___,              ___,
   Key_PcApplication,          Consumer_Mute,          Consumer_VolumeDecrement, Consumer_VolumeIncrement, ___,             Key_Backslash,    Key_Pipe,
   ___, ___, Key_Enter, ___,
   ___)
) // KEYMAPS(
/* Re-enable astyle's indent enforcement */
// *INDENT-ON*
/** versionInfoMacro handles the 'firmware version info' macro
 *  When a key bound to the macro is pressed, this macro
 *  prints out the firmware build information as virtual keystrokes
static void versionInfoMacro(uint8_t keyState) {
  if (keyToggledOn(keyState)) {
    Macros.type(PSTR("Keyboardio Model 01 - Kaleidoscope "));
/** anyKeyMacro is used to provide the functionality of the 'Any' key.
 * When the 'any key' macro is toggled on, a random alphanumeric key is
 * selected. While the key is held, the function generates a synthetic
 * keypress event repeating that randomly selected key.
static void anyKeyMacro(uint8_t keyState) {
  static Key lastKey;
  bool toggledOn = false;
    lastKey.keyCode = Key_A.keyCode + (uint8_t)(millis() % 36);
    toggledOn = true;
  if (keyIsPressed(keyState))
    kaleidoscope::hid::pressKey(lastKey, toggledOn);
  switch (macroIndex) {
  case MACRO_VERSION_INFO:
    versionInfoMacro(keyState);
  case MACRO_ANY:
    anyKeyMacro(keyState);
  return MACRO_NONE;
// These 'solid' color effect definitions define a rainbow of
// LED color modes calibrated to draw 500mA or less on the
// Keyboardio Model 01.
static kaleidoscope::LEDSolidColor solidRed(160, 0, 0);
static kaleidoscope::LEDSolidColor solidOrange(140, 70, 0);
static kaleidoscope::LEDSolidColor solidYellow(130, 100, 0);
static kaleidoscope::LEDSolidColor solidGreen(0, 160, 0);
static kaleidoscope::LEDSolidColor solidBlue(0, 70, 130);
static kaleidoscope::LEDSolidColor solidIndigo(0, 0, 170);
static kaleidoscope::LEDSolidColor solidViolet(130, 0, 120);
/** toggleLedsOnSuspendResume toggles the LEDs off when the host goes to sleep,
 * and turns them back on when it wakes up.
void toggleLedsOnSuspendResume(kaleidoscope::HostPowerManagement::Event event) {
  switch (event) {
  case kaleidoscope::HostPowerManagement::Suspend:
    LEDControl.paused = true;
    LEDControl.set_all_leds_to({0, 0, 0});
    LEDControl.syncLeds();
  case kaleidoscope::HostPowerManagement::Resume:
    LEDControl.paused = false;
    LEDControl.refreshAll();
  case kaleidoscope::HostPowerManagement::Sleep:
/** hostPowerManagementEventHandler dispatches power management events (suspend,
 * resume, and sleep) to other functions that perform action based on these
 * events.
void hostPowerManagementEventHandler(kaleidoscope::HostPowerManagement::Event event) {
  toggleLedsOnSuspendResume(event);
/** This 'enum' is a list of all the magic combos used by the Model 01's
 * firmware The names aren't particularly important. What is important is that
 * each is unique.
 * These are the names of your magic combos. They will be used by the
 * `USE_MAGIC_COMBOS` call below.
enum {
  // Toggle between Boot (6-key rollover; for BIOSes and early boot) and NKRO
  // mode.
  COMBO_TOGGLE_NKRO_MODE
/** A tiny wrapper, to be used by MagicCombo.
 * This simply toggles the keyboard protocol via USBQuirks, and wraps it within
 * a function with an unused argument, to match what MagicCombo expects.
static void toggleKeyboardProtocol(uint8_t combo_index) {
  USBQuirks.toggleKeyboardProtocol();
/** Magic combo list, a list of key combo and action pairs the firmware should
 * recognise.
USE_MAGIC_COMBOS({.action = toggleKeyboardProtocol,
                  // Left Fn + Esc + Shift
                  .keys = { R3C6, R2C6, R3C7 }
// First, tell Kaleidoscope which plugins you want to use.
KALEIDOSCOPE_INIT_PLUGINS(
  // The EEPROMSettings & EEPROMKeymap plugins make it possible to have an
  // editable keymap in EEPROM.
  EEPROMSettings,
  EEPROMKeymap,
  // Focus allows bi-directional communication with the host, and is the
  // interface through which the keymap in EEPROM can be edited.
  Focus,
  // FocusSettingsCommand adds a few Focus commands, intended to aid in
  // changing some settings of the keyboard, such as the default layer (via the
  // `settings.defaultLayer` command)
  FocusSettingsCommand,
  // FocusEEPROMCommand adds a set of Focus commands, which are very helpful in
  // both debugging, and in backing up one's EEPROM contents.
  FocusEEPROMCommand,
  // The boot greeting effect pulses the LED button for 10 seconds after the
  // keyboard is first connected
  BootGreetingEffect,
  // The hardware test mode, which can be invoked by tapping Prog, LED and the
  // left Fn button at the same time.
  TestMode,
  LEDControl,
  LEDOff,
  // The rainbow effect changes the color of all of the keyboard's keys at the same time
  LEDRainbowEffect,
  LEDRainbowWaveEffect,
  LEDChaseEffect,
  solidRed, solidOrange, solidYellow, solidGreen, solidBlue, solidIndigo, solidViolet,
  LEDBreatheEffect,
  // The AlphaSquare effect prints each character you type, using your
  // keyboard's LEDs as a display
  AlphaSquareEffect,
  StalkerEffect,
  // The numpad plugin is responsible for lighting up the 'numpad' mode
  // with a custom LED effect
  NumPad,
  Macros,
  MouseKeys,
  // The HostPowerManagement plugin allows us to turn LEDs off when then host
  // goes to sleep, and resume them when it wakes up.
  HostPowerManagement,
  // The MagicCombo plugin lets you use key combinations to trigger custom
  // actions - a bit like Macros, but triggered by pressing multiple keys at the
  // same time.
  MagicCombo,
  // The USBQuirks plugin lets you do some things with USB that we aren't
  // comfortable - or able - to do automatically, but can be useful
  // nevertheless. Such as toggling the key report protocol between Boot (used
  // by BIOSes) and Report (NKRO).
  USBQuirks
void setup() {
  Kaleidoscope.setup();
  NumPad.numPadLayer = NUMPAD;
  AlphaSquare.color = CRGB(255, 0, 0);
  LEDRainbowEffect.brightness(150);
  LEDRainbowWaveEffect.brightness(150);
  // The LED Stalker mode has a few effects. The one we like is called
  // 'BlazingTrail'. For details on other options, see
  // https://github.com/keyboardio/Kaleidoscope/blob/master/doc/plugin/LED-Stalker.md
  StalkerEffect.variant = STALKER(BlazingTrail);
  // We want to make sure that the firmware starts with LED effects off
  // This avoids over-taxing devices that don't have a lot of power to share
  // with USB devices
  LEDOff.activate();
  // To make the keymap editable without flashing new firmware, we store
  // additional layers in EEPROM. For now, we reserve space for five layers. If
  // one wants to use these layers, just set the default layer to one in EEPROM,
  // by using the `settings.defaultLayer` Focus command.
  EEPROMKeymap.setup(5, EEPROMKeymap.Mode::EXTEND);
  * As you might expect, it runs in a loop, never exiting.
  * For Kaleidoscope-based keyboard firmware, you usually just want to
  * call Kaleidoscope.loop(); and not do anything custom here.
void loop() {
I don’t see anything obviously wrong with your sketch. Does the issue occur when you change layers, or is it apparently random?
The only thing I can think to check would be the EEPROM plugins. I’m really unfamiliar with them, but I wonder if there’s a different keymap stored in memory and the plugin is pulling that out for some reason. If you aren’t actually using them, I’d try removing Focus, EEPROMSettings, and EEPROMKeymap.
Thank you very much for looking at it. If I had to guess, I’d say it was not random. But I couldn’t say what it is, yet. Hasn’t happened since I posted about it, this morning.
Just some notes (perhaps a pattern will emerge).
login at keybr.com
configure keyboard to ‘dvorak’
click ‘emulate’
MUTANT
lock the PC (control alt delete enter)
log back in
CORRECT
replicated this, once.
unclick ‘emulate.’ The browser’s simulator keyboard displays MUTANT, but the actual key is CORRECT.
I think this is solved: user error.
There is a Windows 10 hotkey combination (WIN + SPC) that cycles through enabled keyboard layouts. If I have the PC in the default layout (QWERTY), my custom layout on the M01 works, fine. However: if the PC keyboard layout is changed to DVORAK , I get the MUTANT layout.
Why am I pressing the WIN key, you ask? Well, I’m not actually pressing the key I have mapped to ‘WIN’: I have CTRL, ESC, and SPC all mapped to different thumb keys; every so often, I am mashing “CTRL + ESC + SPC”. “CTRL + ESC” == WIN (another Windows hotkey combination), so “CTRL + ESC + SPC” == “WIN + SPC” was changing the PC keyboard layout and causing me to see MUTANT. My troubleshooting always included cycling through the PC’s keyboard layouts, but I didn’t make the connection until now. The problem was never with the M01. Sorry. Hopefully, this helps someone else.
maybe add the need for the PC keyboard layout to be ‘qwerty/default’ (or maybe it’s for the PC to stay in whatever layout it was in when it the M01 was programmed?) for the M01 layout to work? Maybe just for Windows?
I’ll check if having the PC in DVORAK is what was causing the default layout to be DVORAK, when I have time. My guess is yes…
Whatever the relationship between the M01 layout and the PC layout is, it should be understood and documented. If it is and I missed it, please let me know. Thanks to all.
Ah, yes, that makes sense.
My understanding is that this problem isn’t unique to the M01, and that other Dvorak keyboards exhibit the same behavior. It’s why, even though I exclusively use Colemak, I still keep my M01 on QWERTY mode.
I’m … actually not entirely sure why this is. If you have an AZERTY or QWERTZ keyboard, selecting that in the OS doesn’t screw things up. Thinking about it, I suspect they send the same scancodes as QWERTY boards, and they just have different legends printed on the keycaps. It’s either that, or the OS treats them differently.
You type COLEMAK but your M01 is “on QWERTY mode”? How? Can I type DVORAK but have my M01 “on QWERTY mode”? Maybe that would prevent this? Can you please explain? Thanks.
Don’t change the internal keymap of your keyboard; just change it on your OS. Sorry if I worded it confusingly.
I thought that was what you meant. Thanks! No worries.
