So I want to make a macro layer for strings with a function that takes each macro name and returns the string, like this:
enum { MACRO_VERSION_INFO,
MACRO_ANY,
M_Prog, M_1, M_2, M_3, M_4,
M_5, M_LEDEffectNext,
M_Backtick, M_Q,
M_W,
Ma_E,
M_R,
M_T,
M_Tab,
M_PageUp, M_A, M_S, M_D, M_F, M_G,
M_PageDown, M_Z, M_X, M_C, M_V, M_B, M_Escape,
M_LeftControl, M_Backspace, M_LeftGui, M_LeftShift,
M_LeftFunction,
M_Any, M_6, M_7, M_8, M_9, M_0, M_Numpad,
M_Enter, M_Y, M_U, M_I, M_O, M_P, M_Equals,
M_H, M_J, M_K, M_L, M_Semicolon, M_Quote,
M_RightAlt, M_N, M_M, M_Comma, M_Period, M_Slash, M_Minus,
M_RightShift, M_LeftAlt, M_Spacebar, M_RightControl,
M_RightFunction
char* words(uint8_t macroIndex) {
switch (macroIndex) {
case M_N: return "Hello";
return "Hi";
case MACRO_VERSION_INFO:
versionInfoMacro(keyState);
case MACRO_ANY:
anyKeyMacro(keyState);
case M_Prog: case M_1: case M_2:
case M_3: case M_4: case M_5:
case M_LEDEffectNext:
case M_Backtick: case M_Q: case M_W: case Ma_E:
case M_R: case M_T: case M_Tab:
case M_PageUp: case M_A: case M_S: case M_D:
case M_F: case M_G: case M_PageDown:
case M_Z: case M_X: case M_C: case M_V:
case M_B: case M_Escape: case M_LeftControl:
case M_Backspace: case M_LeftGui: case M_LeftShift:
case M_LeftFunction:
case M_Any: case M_6: case M_7: case M_8:
case M_9: case M_0: case M_Numpad:
case M_Enter: case M_Y: case M_U: case M_I:
case M_O: case M_P: case M_Equals:
case M_H: case M_J: case M_K: case M_L:
case M_Semicolon: case M_Quote: case M_RightAlt:
case M_N: case M_M: case M_Comma: case M_Period:
case M_Slash: case M_Minus: case M_RightShift:
case M_LeftAlt: case M_Spacebar: case M_RightControl:
case M_RightFunction:
if (keyToggledOn(keyState)) {
return Macros.type(PSTR(words(macroIndex)));
return MACRO_NONE;
But I get this error:
In function 'const macro_t* macroAction(uint8_t, uint8_t)':
311: error: initializer fails to determine size of '__c'
311: error: array must be initialized with a brace-enclosed initializer
Why am I getting this error?
