How to set the led color for a single key in a macro?
Is there a way to switch the led color of a single key in a macro?
Here is my use case: I wanted to try SpaceCadet, but I also use OneShot. I was able to get them to work in turns by creating a macro that alternates which of the two is enable/disabled at a given time. Everything works well, except that if I forget in which mode I am in, I need to press a modifier key and check it the color of that key changed (OneShot + ActiveModColor). I would like to have my macro also change the color of a switch (probably led) so I know which mode I am in without having to touch the keyboard.
If you want to see my sketch, it is on GitHub - lgnakano/KeyboardioSketches: Keyboardio Sketch
I found a solution, but I am not sure if this is optimal.
I created a new layer that has only one key that is not transparent, and that is the key that I am using to trigger the macro, but on this new layer, it has a different macro, eg:
[PRIMARY] = KEYMAP_STACKED
M(MACRO_SWITCH_SPACE_CADET)
[SECONDARY] = KEYMAP_STACKED
M(MACRO_SWITCH_SPACE_CADET2)
Both macros trigger the same function:
  switch (macro_id) {
    case MACRO_SWITCH_SPACE_CADET:
    case MACRO_SWITCH_SPACE_CADET2:
      toggleSpaceCadet(event.state);
The function toggles the layer together with the status of SpaceCadet and OneShot:
  static void toggleSpaceCadet(uint8_t key_state) {
		  OneShot.toggleAutoOneShot();
		  if (SpaceCadet.active()) {
                      SpaceCadet.disable();
                      Layer.move(PRIMARY);
		  else {
                     SpaceCadet.enable();
                      Layer.move(SECONDARY);
Since I use custom colors in FunctionalColor for some keys, I just defined the macros to have different colors:
FC_START_COLOR_LIST(customColors)
    //// // Set the color of keys with brightness macros
    //// // Use any number of FCGROUPKEYs above a FC_KEYCOLOR to set several keys to the same color
    FC_KEYCOLOR(M(MACRO_SWITCH_SPACE_CADET), dim(greenyellow, 255))
    FC_KEYCOLOR(M(MACRO_SWITCH_SPACE_CADET2), dim(skyblue, 255))
    FC_KEYCOLOR(Key_CapsLock, dim(purple,128 ))
    FC_END_COLOR_LIST_DEFAULT(dim(forestgreen, 255));
  FunctionalColor funColorCustom(FC_COLOR_LIST(customColors));
Let me know if you know of a better solution, as this seems to use quite a bit of extra memory.
