Mapping multiple modifiers (combo) to one key
I’m curious whether it’s possible to map one key to a combination of keys. For example, to make my left palm key behave as if I pressed ctrl and shift simultaneously.
Has anyone done this? Can it be achieved with current firmware, and how? My naive attempt at Key_LeftShift+Key_LeftControl produced error: no match for 'operator+'…
You can do that specifically for modifiers, using the LCTRL, LSHIFT, etc macros (see here for the definitions). So, you could have LCTRL(LSHIFT(Key_LeftAlt)) and it would be like pressing Control+Shift+Alt.
Awesome! Thank you very much!
