Runic keycap layout
Oh, I didn’t know that. Hmmm… I personally would still go with full key symbols. Looking at my current keyboard, and the full key symbols look better in my opinion. Looking at the num pad which has . and Del on one key, top/bottom respectively, and I don’t like it as much as the arrow keys that are centered and taking up the whole key.
Hrm. Tried the Mende symbols with a larger fonts - not bad. Will try centering the symbols too, and see where that leads.
I’m not likely to sign off on full-key symbols. The light distribution won’t be even. They won’t look great.
Also, to the extent that we can find symbols with a consistent line width, that’ll also laser better.
Sounds good. What is best for the size/position of the symbols? Any particular recommendation on line width? I can modify my symbols to match a specific pixel width in the images.
Another update, with both halves full of symbols. I adjusted some a little, to move them towards the LEDs. Still a work in progress, mind you. As this uses a single font, line widths should be reasonably consistent, I hope.
I may rearrange some of the symbols, but when it comes to positioning, this is the best I can do, I think. If anyone wants it, the SVG source is at https://asylum.madhouse-project.org/algernon/keyboardio/runes.svg. You’ll need this font for it to render properly.
Does the font not have 62 characters? I ask because some of the symbols are re-used.
Another question I have is what everyone else thinks of mirrored halves?
It does, but some of the symbols look very similar. Mind you, if I reused any, that’s a mistake. Except for the thumb arc, that reuse was intentional, but I’ll be changing them, most likely.
Hmm… mirrored sounds intriguing too.
I think the draft layout looks great! I would buy it with only minor tweaks, and since you’re using Unicode and an open font, there should be minimal risk of offending anyone. I do suggest either mirroring the thumb row or making them both unique. Right now, the repeated characters reflect the default keymap’s repeated keys, and I think the consensus has been that we want a layout that privileges no keymap.
Do you prefer the more standardized format of @algernon s font, or the more diverse symbol types in my picture?
That was my thought too. I saw that some characters were re-used in the thumb arc, and that made me think mirrored would look better than partial re-use.
I personally like @algernon’s layout more - the variety of symbols in @adam.ard 's layout, while interesting, is a little too busy for my tastes; I tend to prefer a more subdued & unified style.
I am thinking the same thing, and am going to look into more uniform options for my 2nd attempt.
Left side is the Visitors font, right is the Atlantean font. Visitors is more sci-fi, Atlantean is more fantasy, but both have similar thicknesses.
Thoughts?
@adam.ard: I personally like that design very much! I think the left / right split is a nice touch, although I would prefer the symbols to be a bit larger.
Me too! Next version will increase the size.
I like Atlantean a lot more. Visitors is… I don’t know… too simple, or minimal?
How about this? Increased the size of the fonts, moved a couple Atlantean characters around (I want interesting stuff in thumb row), and adjusted the alignment of each character to match the keycap.
Looks better with the larger font, but the right side has a number of keys with similar symbols: a vertical line with 1, 2 or 3 dots beside it. In the lower right corner, there is two that are just mirrorred horizontally, by the looks of it, and the one above them is very similar too. A bit more variety would be nicer, in my opinion.
The left half seems better in this regard, at least after a quick look. I still like the Atlantean font though, but that’s just a matter of taste.
I had to do some digging, because the font only has 3 upper case characters, so I was limited in what options I had. The boring characters are the numbers, (need 31 characters, have 26 letters). I found that there are 3 uppercase, I replaced the repetitive looking numbers with the uppercase characters.
EDIT: Also, the left side does have a couple characters that are just rotations of the original (Three lines vertical vs three lines horizontal, horiztonal U with dot, same flipped vertically).
Sorry, can’t help it, but still like Menda Kikakui more. I would like consistency between the 2 halfs. And Menda Kikakui also looks more modern than the right half.
