Caps Word plugin?
Is there an equivalent to the Caps Word plugin from QMK or some simple way to replicate it?
There is no existing equivalent to QMK’s Caps Word feature, but it would be a fairly simple plugin to write. If you have a GitHub account, it would be good to submit a feature request issue for it to the Kaleidoscope repository. I will add it to my list of plugins to add when I get time to work on Kaleidoscope, and I won’t forget about it if it’s there.
Done! #1316
If you have any pointers for where to start, I wouldn’t mind trying to port this over myself, if it should be pretty simple…
