This article on the use of Rust macros to define keymaps in QMK might be of interest.
@AmigoNico, thanks for posting that rust-article. I found it very inspiring. It gave me the idea that we could do something similar in Kaleidoscope to make life of non-english speakers easier.
Here’s an example of what C++ has to offer in terms of KEYMAPS readability.
#include "kaleidoscope/host_keymap/linux/eu/standard/keymap.h"
USE_HOST_KEYMAP(linux, eu, standard)
KEYMAPS(
[0] = KEYMAP_STACKED
XXX, "1", "2", "3", "4", "5", XXX,
"`", "q", "w", "e", "r", "t", L"↹",
L"⇞", "ü", "ß", "d", "f", "g",
L"⇟", "z", "x", "c", "v", "b", L"⎋",
L"⌃", L"⌫", L"⌘", L"⇧",
XXX,
XXX, "6", "7", "8", "9", "0", XXX,
L"⎆", "y", "u", "i", "o", "p", "=",
"h", "j", "k", "l", ";", "\"",
XXX, "n", "m", ",", ".", "/", "-",
L"r⇧", L"r⌥", L"␣", L"r⌃",
XXX
Not exactly as convenient as what rust has to offer (quotes ), but close. And still way more convenient than fiddeling with
Key_...
values directly (especially on non-us keymaps). ASCII characters can be supplied double quotes, utf-8 unicode characters come with a leading L
I submitted a PR to Kaleidoscope
The newly implemented system supports all 633 keymaps currently available on GNU/Linux out of the box (untested on other OS but hopefully still useful there). It allows not only to use utf-8 characters directly in the Kaleidoscope KEYMAP, but those characters will automatically generate the matching characters on the host as long as the host-keymap used in the sketch and the actual keymap running on the host do match.
That does away with the burden to wrap ones head around the question what-Key
-do-I-have-to-put-in-the-KEYMAP-for-it-to-create-a-specific-symbol-on-the-host.
Apart from utf-8 printable characters, the new system also supports a set of control-characters like ⌫, ⇧, … for common actions like backspace, shift, enter, … Those are the characters that are typically printed on the keys.
Disclaimer: I can only hope but not guarantee that this PR is going to be accepted in its present form. I only post it here as I think it will be useful for non-english speakers and, if so, it might take a while for it to pass t review process.
Nice work! Whether in its present form or not, I hope something comes of it.
