Hi,
I just got my Model 01 and I’m trying to flash algernon’s firmware.
Arduino IDE is installed, installed keybordio board, downloaded the example firmare and I able to flash the keyboardio.
I’ve cloned locally algernon’s repository, entered it, typed make setup followed by make flash, hold prog and press enter
There is an error but it still flashes the board and the keyboards acts weirdly after. What do I do wrong?
here is the error :
Sylvains-MacBook-Pro:algernon sylvain$ make flash
BOARD_HARDWARE_PATH="./lib/hardware" ./lib/hardware/keyboardio/avr/libraries/Kaleidoscope/bin//kaleidoscope-builder flash
Building src/algernon 0.0.0 into /var/folders/np/x4646kv15l19sh8l_q21j6gw0000gn/T//kaleidoscope-sylvain/sketch/12898088092-algernon.ino/output...
- Size: firmware/algernon/algernon-0.0.0.elf
- Program: 26560 bytes (92.6% Full)
- Data: 1261 bytes (49.3% Full)
To update your keyboard's firmware, hold down the 'Prog' key on your keyboard,
and then press 'Enter'.
When the 'Prog' key glows red, you can release it.
2019-10-30 21:40:45.376 system_profiler[73578:3758455] SPUSBDevice: IOCreatePlugInInterfaceForService failed 0xe00002be
2019-10-30 21:40:48.630 system_profiler[73587:3758592] SPUSBDevice: IOCreatePlugInInterfaceForService failed 0xe00002be
Connecting to programmer: .
Device code: 0x44
