Hand/Thumbposition
Hi,
this feels like a natural hand position to me.
But then how to type on the thumb keys? I could “fold” my thumb like this, but that feels unergonomic/unnatural to me.
Should I hold my hand in a different way?
Are the proportions of my hand just not a good fit for the model 01?
I am looking for any kind of feedback or advice.
Comparing my hand position to your pictures, I find that I’m flattening out my hand a bit more so that the end of my thumb lines up with the thumb keys.
The only key I find particularly uncomfortable is the fn keys - since I’ve got relatively large hands, they line up almost exactly with knuckle that’s about halfway down my thumb. I’d be a lot happier if they were truly palm keys.
If you hold your hand in a more flat position, can you reach the number keys without moving your hand?
