How to enable 'layer shift when held' option in Chrysalis?
I want to set my Space and Backspace keys of my Atreus to shift to layers when held, but I don’t have the toggle “Layer shift when held, normal key otherwise” in Chrysalis. I already set up an Arduino environment following the documentation. What else should I do?
Oh, I feel like an idiot now. It seem like the toggle was already there, but just cropped out from the window. Resizing the Chrysalis window did the trick.
Yep, Chrysalis need some space to show some fields :frowning:
And for the record, if you compile your own firmware and things don’t work as expected, check if all the required plugins are included !
