Hello guys! ![]()
I am recently purchased a Model 01. I’m really excited about the potential it has to enhance my typing experience, but I’m a bit overwhelmed with the customization options available.
I am eager to optimize my Keyboardio Model 01 for coding and overall efficiency. I’m particularly interested in tailoring my layout for:
- What key mappings and shortcuts have you found most beneficial for working with Python, JavaScript, and SQL?
- How have you customized your keyboard to streamline window management and application switching? Any shortcuts for frequently used apps?
- What key arrangements can help prevent strain during long coding sessions? I’m focused on avoiding repetitive strain injuries.
- For those who’ve dramatically customized their keyboard, how long did it take to adjust? Any tips for a smoother transition?
I also check this: https://community.keyboard.io/t/needing-advice-on-non-responding-contactqliksense But I have not found any solution. Could anyone suggest the best solution for this?
Thanks in advance… ![]()
Respected community member! ![]()
