Macro with multiple modifiers
I’m attempting to port a macro to Kaleidoscope that enters a different set of enclosures depending on the modifier pressed. This is what I have:
#define K_LT     LSHIFT(Key_Comma)
#define K_GT     LSHIFT(Key_Period)
#define K_LParen LSHIFT(Key_9)
#define K_RParen LSHIFT(Key_0)
namespace kaleidoscope {
  namespace plugin {
    class ModBlocker : public Plugin {
      public:
        EventHandlerResult onAddToReport(Key key) {
          if (active_ && key.isKeyboardModifier())
            return EventHandlerResult::ABORT;
        void enable() {
          active_ = true;
        void disable() {
          active_ = false;
      private:
        bool active_{false};
kaleidoscope::plugin::ModBlocker ModBlocker;
  switch (macro_id) {
  case MACRO_VERSION_INFO:
    versionInfoMacro(event.state);
  case MACRO_BRACES:
      if (Kaleidoscope.hid().keyboard().wasModifierKeyActive(Key_LeftAlt)) {
        Macros.tap(K_LParen);
        Macros.tap(K_RParen);
      else if (Kaleidoscope.hid().keyboard().wasModifierKeyActive(Key_LeftControl)) {
        Macros.tap(K_LT);
        Macros.tap(K_GT);
      else {
        // this handles shift too
        Macros.tap(Key_LeftBracket);
        Macros.tap(Key_RightBracket);
      ModBlocker.enable();
      Macros.tap(Key_LeftArrow);
      ModBlocker.disable();
      return MACRO_NONE;
  return MACRO_NONE;
The ModBlocker plugin is based on the ShiftBlocker example, but the enable does not work so the LeftArrow tap is getting mangled. Any suggestions?
Can anyone confirm if the regular ShiftBlocker works with a current checkout? I can’t get it to work, either.
