Macros with modifiers
I would like to make a macro that does one thing when shift is pressed and another thing when shift is not pressed. Is there a way to do that?
How do I detect what modifiers are pressed when I run the macro?
Keyboard.wasModifierActive(Key mapped_key);
Thanks - I’m not sure I understand how that works.
Do I use that within a macro?
Does it return true if any modifier was on? How do I determine which modifier was on? Do I use wasLeftShiftActive(), was LeftControlActive(), etc.?
Oh ok, it’s wasModifierActive(Key_LeftShift).
These threads are also helpful:
Sorry for not providing more information; I was short on time just then.
If I use kaleidoscope::hid::wasModifierKeyActive it works fine. But with Keyboard.wasModifierActive I get the following error:
E:\User\Documents\Arduino\Model01-Firmware-Jeremy\Model01-Firmware-Jeremy.ino: In function 'const macro_t* macroAction(uint8_t, uint8_t)':
Model01-Firmware-Jeremy:683: error: no matching function for call to 'Keyboard_::wasModifierActive(Key)'
         if (Keyboard.wasModifierActive(Key_LeftShift) || Keyboard.wasModifierActive(Key_RightShift))
E:\User\Documents\Arduino\Model01-Firmware-Jeremy\Model01-Firmware-Jeremy.ino:683:53: note: candidate is:
In file included from C:\Users\User\AppData\Local\Arduino15\packages\keyboardio\hardware\avr\1.22.0\libraries\KeyboardioHID\src/KeyboardioHID.h:48:0,
                 from C:\Users\User\AppData\Local\Arduino15\packages\keyboardio\hardware\avr\1.22.0\libraries\Kaleidoscope\src/key_defs.h:16,
                 from C:\Users\User\AppData\Local\Arduino15\packages\keyboardio\hardware\avr\1.22.0\libraries\Kaleidoscope\src/key_events.h:5,
                 from C:\Users\User\AppData\Local\Arduino15\packages\keyboardio\hardware\avr\1.22.0\libraries\Kaleidoscope\src/Kaleidoscope.h:24,
                 from E:\User\Documents\Arduino\Model01-Firmware-Jeremy\Model01-Firmware-Jeremy.ino:26:
C:\Users\User\AppData\Local\Arduino15\packages\keyboardio\hardware\avr\1.22.0\libraries\KeyboardioHID\src/MultiReport/Keyboard.h:60:11: note: boolean Keyboard_::wasModifierActive(uint8_t)
   boolean wasModifierActive(uint8_t k);
I believe this is the “correct” / encouraged way to do this (it uses the Kaleidoscope HID facade). User code should “not” use HID objects like Keyboard directly. Someone else can correct me if I’m wrong.
