I have a Model 01 that I never unboxed from the original Kickstarter; I’m attempting to update it to match my in use Model 01 (setup using Chrysalis v0.12.0), but Chrysalis cannot connect with a Communication timeout error.
I briefly tried directly flashing the firmware via the Arduino software (Windows), but ran into both compile problems (Remove-Item : A positional parameter cannot be found that accepts argument), and I cannot put the Model 01 into programming mode (at least not for long). I hold the prog button while inserting the USB cable and the Prog light turns red, but only for about 10 seconds.
Aside - I can type with the keyboard just fine, I just can’t flash the firmware.
Any ideas? If the only/best/next path forward is to manually flash the firmware I can switch over to Linux and make it work over there (though a pointer to the correct firmware file would be helpful - it’s not obvious which firmware file to use from here).
Thanks
