I had to do a bit of maintenance and decided to take a few pictures as I was blown away by how well the M01 is both designed and executed in build.
I am not sure how many people will end up opening their M01s so I thought I would take a moment to say, it is very easy to do. The board sits precisely into the plastic base so it is easily aligned and the provided tool is all you would need.
I will be taking my M01 apart for bi-yearly cleaning. ( I try not to eat at my desk but from time to time it happens )
