I’m having a new problem updating my Keyboard’s firmware. I’ve tried several different things, including wiping Arduino from my system and starting from scratch. When I select my port and a select the Keyboardio board, I am able to compile. I go to upload, and the Prog key turns red when held (and it displays “Found upload port: /dev/cu.usbmodembio01”), but the upload times out. No more red flashing lights on the keyboard, as in the past. I get this error report:
Arduino: 1.8.5 (Mac OS X), Board: “Keyboardio Model 01”
Sketch uses 20712 bytes (72%) of program storage space. Maximum is 28672 bytes.
Global variables use 1794 bytes (70%) of dynamic memory, leaving 766 bytes for local variables. Maximum is 2560 bytes.
Forcing reset using 1200bps open/close on port /dev/cu.usbmodemCDkbio01
PORTS {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.JasonsAirPods-Wirelessi-1, /dev/cu.usbmodemCDkbio01, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.JasonsAirPods-Wirelessi-1, /dev/tty.usbmodemCDkbio01, } / {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.JasonsAirPods-Wirelessi-1, /dev/cu.usbmodemCDkbio01, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.JasonsAirPods-Wirelessi-1, /dev/tty.usbmodemCDkbio01, } => {}
PORTS {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.JasonsAirPods-Wirelessi-1, /dev/cu.usbmodemCDkbio01, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.JasonsAirPods-Wirelessi-1, /dev/tty.usbmodemCDkbio01, } / {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.JasonsAirPods-Wirelessi-1, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.JasonsAirPods-Wirelessi-1, } => {}
PORTS {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.JasonsAirPods-Wirelessi-1, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.JasonsAirPods-Wirelessi-1, } / {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.JasonsAirPods-Wirelessi-1, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.JasonsAirPods-Wirelessi-1, } => {}
PORTS {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.JasonsAirPods-Wirelessi-1, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.JasonsAirPods-Wirelessi-1, } / {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.JasonsAirPods-Wirelessi-1, /dev/cu.usbmodemkbio01, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.JasonsAirPods-Wirelessi-1, /dev/tty.usbmodemkbio01, } => {/dev/cu.usbmodemkbio01, /dev/tty.usbmodemkbio01, }
Found upload port: /dev/cu.usbmodemkbio01
/Users/Jason/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9/bin/avrdude -C/Users/Jason/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9/etc/avrdude.conf -v -patmega32u4 -cavr109 -P/dev/cu.usbmodemkbio01 -b57600 -D -Uflash:w:/var/folders/gl/thjd2mds1959_52fl9v7wb2r0000gn/T/arduino_build_825975/Model01-Firmware.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:01:35
Copyright © 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright © 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/Jason/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9/etc/avrdude.conf"
User configuration file is "/Users/Jason/.avrduderc"
Using Port : /dev/cu.usbmodemkbio01
Using Programmer : avr109
Overriding Baud Rate : 57600
avrdude: ser_open(): can’t open device “/dev/cu.usbmodemkbio01”: No such file or directory
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Any ideas what I’m doing wrong?
