Uneven keyswitch force with loud-click switches
A tiny bit of variation key to key is indeed ‘normal’
It looks like you’re seeing what I thought you might be seeing - The new Matias loud-click switches bind pretty significantly when hit off-axis. :confused:
I suspect that it’s a combination you acclimating and the switches wearing down a little bit on the edges where they were sticking. The loud-click switches aren’t prelubricated.
@jesse I’m willing to do the coin test on my loud click board if you need another data point. I definitely feel like there is a lot of binding on off-center keypresses.
My two quiet click boards definitely feel a lot smoother than my loud click board.
I certainly wouldn’t object to more data :slight_smile:
it’s definitely severe off-center sticking, like you say. it’s been there since the beginning and i don’t think it’s changed much at all. i’ve got a little bit better at hitting on-center obviously, but i think it’s all me and not the keys getting smoother or anything
i’m certain that some keys are just a bit stickier in general too, even when hit on-center. either that or some of them somehow have a default off-center bias or something
is this covered by warranty (ie. do you just organise for matias to ship me the new innards), or do i have to do that myself?
let me know if you need anything else! cheers
To figure out what we can do for you warrantywise, email us at help@keyboard.io. I do suspect that any mitigation is going to involve quiet-click switches, as, to the best pf my understanding, this isn’t something that Matias believes is a defect in the switches.
done! cheers mate
