After flashing on os x, no keypresses sent
I had been happily updating my keyboard using my programmer dvorak layout at https://gist.github.com/benshine/64ecb605bc822bd90ac686e66a02b3d4 , and then I just tried flashing @algernon’s rad layout https://github.com/algernon/Model01-sketch … That put the keyboard into a weird state (one half white, the other half no LEDs, no keypresses sent) so I tried to get back to either my layout or the default, using the Arduino UI. I can’t get it back to generating any keypresses at all.
The one thing that works right now, afaict, is the LED button – it changes the LED mode. That’s the only sign of life.
When I flash using Ardunio UI, I get this message:
Archiving built core (caching) in: /var/folders/2b/p4bk_ptx31n2578xq79ktnzc0000gn/T/arduino_cache_253323/core/core_keyboardio_avr_model01_51f02b7210b938436b779d1c032618e1.a
Sketch uses 18914 bytes (65%) of program storage space. Maximum is 28672 bytes.
Global variables use 1940 bytes (75%) of dynamic memory, leaving 620 bytes for local variables. Maximum is 2560 bytes.
Low memory available, stability problems may occur.
I tried rebooting my mac to make sure it wasn’t talking about low memory on the host OS; no joy.
I had to hard-reset it once already; I think I’m about ready to do that again.
Any suggestions here? I’ve already asked @algernon :slight_smile:
I’ll update this thread after I reset the board & confirm that it’s happy again.
Here’s output from the upload:
Sketch uses 20888 bytes (72%) of program storage space. Maximum is 28672 bytes.
Global variables use 1988 bytes (77%) of dynamic memory, leaving 572 bytes for local variables. Maximum is 2560 bytes.
Forcing reset using 1200bps open/close on port /dev/cu.usbmodemCkbio01
PORTS {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.usbmodemCkbio01, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.usbmodemCkbio01, } / {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.usbmodemCkbio01, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.usbmodemCkbio01, } => {}
PORTS {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.usbmodemCkbio01, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.usbmodemCkbio01, } / {/dev/cu.Bluetooth-Incoming-Port, /dev/tty.Bluetooth-Incoming-Port, } => {}
PORTS {/dev/cu.Bluetooth-Incoming-Port, /dev/tty.Bluetooth-Incoming-Port, } / {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.usbmodemkbio01, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.usbmodemkbio01, } => {/dev/cu.usbmodemkbio01, /dev/tty.usbmodemkbio01, }
Found upload port: /dev/cu.usbmodemkbio01
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -P/dev/cu.usbmodemkbio01 -b57600 -D -Uflash:w:/var/folders/2b/p4bk_ptx31n2578xq79ktnzc0000gn/T/arduino_build_602119/Model01-programmer-dvorak.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:01:35
         System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/ben/.avrduderc"
         Using Port                    : /dev/cu.usbmodemkbio01
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : butterfly
         Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .
    Device code: 0x44
avrdude: devcode selected: 0x44
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9587 (probably m32u4)
avrdude: reading input file "/var/folders/2b/p4bk_ptx31n2578xq79ktnzc0000gn/T/arduino_build_602119/Model01-programmer-dvorak.ino.hex"
avrdude: writing flash (20888 bytes):
Writing | ################################################## | 100% 2.74s
avrdude: 20888 bytes of flash written
avrdude: verifying flash memory against /var/folders/2b/p4bk_ptx31n2578xq79ktnzc0000gn/T/arduino_build_602119/Model01-programmer-dvorak.ino.hex:
avrdude: load data flash data from input file /var/folders/2b/p4bk_ptx31n2578xq79ktnzc0000gn/T/arduino_build_602119/Model01-programmer-dvorak.ino.hex:
avrdude: input file /var/folders/2b/p4bk_ptx31n2578xq79ktnzc0000gn/T/arduino_build_602119/Model01-programmer-dvorak.ino.hex contains 20888 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 1.31s
avrdude: verifying ...
avrdude: 20888 bytes of flash verified
avrdude done.  Thank you.
Well, dang. I took the left enclosure off, and I’m pressing the reset button, but I can’t get my keyboard to work again at all. I’ve tried several different orders of operation for hitting the reset button, hitting the upload button, and hitting the prog button – it all comes to naught though.
Procedure:
  1. in Arduino GUI, go to File => Examples => Keyboard IO => Model 01 Firmware
  2. With left enclosure removed, depress then release the little white button. The red light behind the prog button comes on.
  3. Hit the right-arrow in arduino UI that means 'upload’
    The red light for the prog key goes out; the blue light under the LED key goes on briefly, then goes off.
    about another 1min goes by, ending with the selected serial port does not exist or your board is not connected.
Complete output from upload:
Sketch uses 18972 bytes (66%) of program storage space. Maximum is 28672 bytes.
Global variables use 1941 bytes (75%) of dynamic memory, leaving 619 bytes for local variables. Maximum is 2560 bytes.
PORTS {/dev/cu.Bluetooth-Incoming-Port, /dev/tty.Bluetooth-Incoming-Port, } / {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.usbmodemCkbio01, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.usbmodemCkbio01, } => {/dev/cu.usbmodemCkbio01, /dev/tty.usbmodemCkbio01, }
Found upload port: /dev/cu.usbmodemCkbio01
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -P/dev/cu.usbmodemCkbio01 -b57600 -D -Uflash:w:/var/folders/2b/p4bk_ptx31n2578xq79ktnzc0000gn/T/arduino_build_182967/Model01-Firmware.ino.hex:i
         Using Port                    : /dev/cu.usbmodemCkbio01
         PAGEL                         : PD7
         BS2                           : PA0
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
Found programmer: Id = ""; type = (
    Software Version = .�; Hardware Version = .
         this check.
and yet, i can’t send keypresses; the one thing that seems to work is changing LED mode.
How can I get back to factory state? I saw @jesse’s thread Flashing problem on Ubuntu (SOLVED) but that is both off the cuff and perhaps linux specific.
I’m using OS X 10.13.1.
Did you pull Arduino-Boards with git or are you using the Arduino ‘boards manager’?
Ah, I forgot I had pulled a ton of different stuff along the way of trying to get @algernon’s layout to build! I removed all of that and now my keyboard is back to running my own layout well! Hooray!
Okay, so now I know I can get back to my good state. Thanks, @jesse! I’ll try @algernon’s setup again after I get my homework done for this week :wink:
I suspect that what really happened was that you got the benefit of me having merged fixes for some stuff that badly broke OSX. :wink:
But happy to hear that it’s behaving now.
