After experimenting further, I found that the real issue seems to lie with the EEPROM/Chrysalis.
In my custom sketch I have defined the following (copied from somewhere)
USE_MAGIC_COMBOS({.action = toggleKeyboardProtocol,
// Left Fn + Esc + Shift
.keys = {R3C6, R2C6, R3C7}},
{.action = enterHardwareTestMode,
// Left Fn + Prog + LED
.keys = {R3C6, R0C0, R0C6}},
{.action = toggleKeymapSource,
// Left Fn + Prog + Shift
.keys = {R3C6, R0C0, R3C7}});
The above lets me switch between the keymap defined in the sketch and the one in Chrysalis, through the Fn + Prog + Shift command, doing so indeed confirms that my sketch is there intact and working perfectly.
What I find odd is then that I don’t seem to be able to “Reset EEPROM to factory defaults” in Chrysalis, it doesn’t seem to do anything. Doing so still makes the EEPROM keymap override the sketch keymap. So to me it seems like I can’t use the sketch keymap unless I specifically use the Fn + Prog + Shift command to switch keymap every time the keyboard is powered on.
I was able to restore a previously working EEPROM .json and manually adjust it in a text editor to get the exact same behavior as my sketch, making the “boot-into-EEPROM-issue” not much of an issue at the moment, although annoying.
Below is the code for my sketch:
// -*- mode: c++ -*-
// Copyright 2016-2022 Keyboardio, inc. <jesse@keyboard.io>
#ifndef BUILD_INFORMATION
#define BUILD_INFORMATION "locally built"
#endif
* These #include directives pull in the Kaleidoscope firmware core,
* as well as the Kaleidoscope plugins we use in the Model 01's firmware
// The Kaleidoscope core
#include "Kaleidoscope.h"
// Support for storing the keymap in EEPROM
#include "Kaleidoscope-EEPROM-Settings.h"
#include "Kaleidoscope-EEPROM-Keymap.h"
// Support for communicating with the host via a simple Serial protocol
#include "Kaleidoscope-FocusSerial.h"
// Support for querying the firmware version via Focus
//#include "Kaleidoscope-FirmwareVersion.h" // UNSUPPORTED IN MODEL 01
// Support for macros
// Support for "Numpad" mode, which is mostly just the Numpad specific LED mode
//#include "Kaleidoscope-NumPad.h"
// Support for the "Boot greeting" effect, which pulses the 'LED' button for 10s
// Support for LED modes that set all LEDs to a single color
// Support for an LED mode that makes all the LEDs 'breathe'
//#include "Kaleidoscope-LEDEffect-Breathe.h"
//#include "Kaleidoscope-LEDEffect-Chase.h"
// Support for LED modes that pulse the keyboard's LED in a rainbow pattern
// Support for an LED mode that prints the keys you press in letters 4px high
//#include "Kaleidoscope-LED-AlphaSquare.h"
// Support for shared palettes for other plugins, like Colormap below
//#include "Kaleidoscope-LED-Palette-Theme.h"
// Support for an LED mode that lets one configure per-layer color maps
//#include "Kaleidoscope-Colormap.h"
// Support for turning the LEDs off after a certain amount of time
#include "Kaleidoscope-IdleLEDs.h"
// Support for setting and saving the default LED mode
//#include "Kaleidoscope-DefaultLEDModeConfig.h" // UNSUPPORTED IN MODEL 01
// Support for changing the brightness of the LEDs
//#include "Kaleidoscope-LEDBrightnessConfig.h" // UNSUPPORTED IN MODEL 01
// Support for Keyboardio's internal keyboard testing mode
#include "Kaleidoscope-HardwareTestMode.h"
// Support for host power management (suspend & wakeup)
#include "Kaleidoscope-HostPowerManagement.h"
// Support for magic combos (key chords that trigger an action)
#include "Kaleidoscope-MagicCombo.h"
// Support for USB quirks, like changing the key state report protocol
#include "Kaleidoscope-USB-Quirks.h"
// Support for secondary actions on keys
//#include "Kaleidoscope-Qukeys.h" // UNNECESSARY
// Support for one-shot modifiers and layer keys
#include "Kaleidoscope-OneShot.h"
#include "Kaleidoscope-Escape-OneShot.h"
// Support for tap tance keys
#include "Kaleidoscope-TapDance.h"
// Support for highlighting active mod key
#include "Kaleidoscope-LED-ActiveModColor.h"
// Support for dynamic, Chrysalis-editable macros
#include "Kaleidoscope-DynamicMacros.h"
// Support for SpaceCadet keys
//#include "Kaleidoscope-SpaceCadet.h" // UNNECESSARY
// Support for editable layer names
//#include "Kaleidoscope-LayerNames.h" // UNSUPPORTED IN MODEL 01
#include "custom_key_defs.h"
/** This 'enum' is a list of all the macros used by the Model 01's firmware
* The names aren't particularly important. What is important is that each
* is unique.
* These are the names of your macros. They'll be used in two places.
* The first is in your keymap definitions. There, you'll use the syntax
* `M(MACRO_NAME)` to mark a specific keymap position as triggering `MACRO_NAME`
* The second usage is in the 'switch' statement in the `macroAction` function.
* That switch statement actually runs the code associated with a macro when
* a macro key is pressed.
enum {
AA
,AE
,OE
/** The Model 01's key layouts are defined as 'keymaps'. By default, there are three
* keymaps: The standard QWERTY keymap, the "Function layer" keymap and the "Numpad"
* keymap.
* Each keymap is defined as a list using the 'KEYMAP_STACKED' macro, built
* of first the left hand's layout, followed by the right hand's layout.
* Keymaps typically consist mostly of `Key_` definitions. There are many, many keys
* defined as part of the USB HID Keyboard specification. You can find the names
* (if not yet the explanations) for all the standard `Key_` defintions offered by
* Kaleidoscope in these files:
* https://github.com/keyboardio/Kaleidoscope/blob/master/src/kaleidoscope/key_defs/keyboard.h
* https://github.com/keyboardio/Kaleidoscope/blob/master/src/kaleidoscope/key_defs/consumerctl.h
* https://github.com/keyboardio/Kaleidoscope/blob/master/src/kaleidoscope/key_defs/sysctl.h
* https://github.com/keyboardio/Kaleidoscope/blob/master/src/kaleidoscope/key_defs/keymaps.h
* Additional things that should be documented here include
* using ___ to let keypresses fall through to the previously active layer
* using XXX to mark a keyswitch as 'blocked' on this layer
* using ShiftToLayer() and LockLayer() keys to change the active keymap.
* keeping NUM and FN consistent and accessible on all layers
* The PROG key is special, since it is how you indicate to the board that you
* want to flash the firmware. However, it can be remapped to a regular key.
* When the keyboard boots, it first looks to see whether the PROG key is held
* down; if it is, it simply awaits further flashing instructions. If it is
* not, it continues loading the rest of the firmware and the keyboard
* functions normally, with whatever binding you have set to PROG. More detail
* here: https://community.keyboard.io/t/how-the-prog-key-gets-you-into-the-bootloader/506/8
* The "keymaps" data structure is a list of the keymaps compiled into the firmware.
* The order of keymaps in the list is important, as the ShiftToLayer(#) and LockLayer(#)
* macros switch to key layers based on this list.
* A key defined as 'ShiftToLayer(FUNCTION)' will switch to FUNCTION while held.
* Similarly, a key defined as 'LockLayer(NUMPAD)' will switch to NUMPAD when tapped.
* Layers are "0-indexed" -- That is the first one is layer 0. The second one is layer 1.
* The third one is layer 2.
* This 'enum' lets us use names like QWERTY, FUNCTION, and NUMPAD in place of
* the numbers 0, 1 and 2.
enum { PRIMARY, NUMPAD, FUNCTION }; // layers
//#define PRIMARY_KEYMAP_COLEMAK_NN_EN
#define PRIMARY_KEYMAP_COLEMAK_NN_SE
// enum { LEFT_ENCLOSURES, RIGHT_ENCLOSURES };
/* This comment temporarily turns off astyle's indent enforcement
* so we can make the keymaps actually resemble the physical key layout better
// *INDENT-OFF*
KEYMAPS(
#if defined (PRIMARY_KEYMAP_COLEMAK_NN_EN)
[PRIMARY] = KEYMAP_STACKED
(Key_Escape, Key_EXCLM, Key_DQuot, Key_STAR, Key_Equals, Key_AT, Key_PRCNT,
Key_Pipe, Key_Q, Key_W, Key_F, Key_P, Key_G, Key_LPar,
Key_AND, Key_A, Key_R, Key_S, Key_T, Key_D,
OSM(LeftGui), Key_Z, Key_X, Key_C, Key_V, Key_B, Key_LT,
OSM(LeftControl), Key_Backspace, OSM(LeftShift), OSM(LeftAlt),
OSL(NUMPAD),
Key_Tilde, Key_HASH, Key_Quest, Key_Minus, Key_Plus, Key_DOLLR, Key_CARET,
Key_RPar, Key_J, Key_L, Key_U, Key_Y, Key_USc, Key_Colon,
Key_H, Key_N, Key_E, Key_I, Key_O, Key_Semicolon,
Key_GT, Key_K, Key_M, Key_Comma, Key_Period, Key_Slash, Key_PcApplication,
Key_Tab, Key_Enter, Key_Spacebar, Key_Delete,
OSL(FUNCTION)),
[NUMPAD] = KEYMAP_STACKED
___, ___, ___, ___, ___, Consumer_VolumeIncrement, Key_LeftBracket,
Consumer_Mute, Consumer_ScanPreviousTrack, Consumer_ScanNextTrack, LGUI(Key_LeftArrow), LGUI(Key_RightArrow), Consumer_PlaySlashPause,
___, ___, ___, LCTRL(LGUI(Key_LeftArrow)), LCTRL(LGUI(Key_RightArrow)), Consumer_VolumeDecrement, ___,
___, ___, ___, ___,
___,
___, ___, Key_Keypad7, Key_Keypad8, Key_Keypad9, Key_KeypadSubtract, LockLayer(NUMPAD),
Key_RightBracket, ___, Key_Keypad4, Key_Keypad5, Key_Keypad6, Key_KeypadAdd, ___,
___, Key_Keypad1, Key_Keypad2, Key_Keypad3, ___, ___,
___, ___, Key_Keypad0, ___, ___, ___, ___,
___, ___, ___, ___,
___),
[FUNCTION] = KEYMAP_STACKED
(___, ___, Key_Quote, ___, ___, ___, Key_F6,
___, Key_F1, Key_F2, Key_F3, Key_F4, Key_F5, Key_LCB,
Key_Pause, Key_LeftArrow, Key_UpArrow, Key_DownArrow, Key_RightArrow, ___,
___, ___, ___, ___,
___,
Key_F7, Key_Insert, ___, ___, ___, ___, Key_LEDEffectNext,
Key_RCB, Key_F8, Key_F9, Key_F10, Key_F11, Key_F12, ___,
___, Key_Home, Key_PageUp, Key_PageDown, Key_End, Key_PrintScreen,
Key_Backtick, ___, M(AE), M(OE), M(AA), Key_Backslash, ___,
___, ___, ___, ___,
___)
#elif defined (PRIMARY_KEYMAP_COLEMAK_NN_SE)
(Key_Escape, Key_SE_EXCLM, Key_SE_DQuot, Key_SE_STAR, Key_SE_Equals, Key_SE_AT, Key_SE_PRCNT,
Key_SE_Pipe, Key_Q, Key_W, Key_F, Key_P, Key_G, Key_SE_LPar,
Key_SE_AND, Key_A, Key_R, Key_S, Key_T, Key_D,
OSM(LeftGui), Key_Z, Key_X, Key_C, Key_V, Key_B, Key_SE_LT,
OSL(NUMPAD),
Key_SE_Tilde, Key_SE_HASH, Key_SE_Quest, Key_SE_Minus, Key_SE_Plus, Key_SE_DOLLR, Key_SE_CARET,
Key_SE_RPar, Key_J, Key_L, Key_U, Key_Y, Key_SE_USc, Key_SE_Colon,
Key_H, Key_N, Key_E, Key_I, Key_O, Key_SE_Semicolon,
Key_SE_GT, Key_K, Key_M, Key_SE_Comma, Key_SE_Period, Key_SE_Slash, Key_PcApplication,
OSL(FUNCTION)),
___, ___, ___, ___, ___, Consumer_VolumeIncrement, Key_SE_LBR,
___, ___, ___, ___,
___,
Key_SE_RBR, ___, Key_Keypad4, Key_Keypad5, Key_Keypad6, Key_KeypadAdd, ___,
___, ___, ___, ___,
___),
(___, ___, Key_SE_Quote, ___, ___, ___, Key_F6,
___, Key_F1, Key_F2, Key_F3, Key_F4, Key_F5, Key_SE_LCB,
___, ___, ___, ___, ___, ___, Key_SE_Acute,
___, ___, ___, ___,
___,
Key_SE_RCB, Key_F8, Key_F9, Key_F10, Key_F11, Key_F12, ___,
Key_SE_Backtick, Key_SE_Diaresis, Key_SE_AE, Key_SE_OE, Key_SE_AA, Key_SE_Backslash, ___,
___, ___, ___, ___,
___)
#else
#error "No default keymap defined. You should make sure that you have a line like '#define PRIMARY_KEYMAP_QWERTY' in your sketch"
#endif
) // KEYMAPS(
/* Re-enable astyle's indent enforcement */
// *INDENT-ON*
static void press(Key key) {
Kaleidoscope.hid().keyboard().pressKey(key);
//Kaleidoscope.hid().keyboard().sendKeyboardReport();
Kaleidoscope.hid().keyboard().sendReport();
static void release(Key key) {
Kaleidoscope.hid().keyboard().releaseKey(key);
static void tap(Key key) {
press(key);
release(key);
//const macro_t *typeAltCombination(uint8_t keyState, const Key key1, const Key key2, const Key key3) {
void typeAltCombination(uint8_t keyState, const Key key1, const Key key2, const Key key3) {
if (!keyToggledOn(keyState)) {
return;
press(Key_LeftAlt);
tap(key1);
tap(key2);
tap(key3);
release(Key_LeftAlt);
I(20) is used to add delay between keys, otherwise we might get something random
bool shiftOn = Kaleidoscope.hid().keyboard().wasModifierKeyActive(Key_LeftShift)
|| Kaleidoscope.hid().keyboard().wasModifierKeyActive(Key_RightShift);
switch (macroIndex) {
case AA:
// Alt + 143 / 134
if (shiftOn) {
typeAltCombination(keyState, Key_Keypad1, Key_Keypad4, Key_Keypad3);
else {
typeAltCombination(keyState, Key_Keypad1, Key_Keypad3, Key_Keypad4);
case AE:
// Alt + 142 / 132
if (shiftOn) {
typeAltCombination(keyState, Key_Keypad1, Key_Keypad4, Key_Keypad2);
else {
typeAltCombination(keyState, Key_Keypad1, Key_Keypad3, Key_Keypad2);
case OE:
// Alt + 153 / 148
if (shiftOn) {
typeAltCombination(keyState, Key_Keypad1, Key_Keypad5, Key_Keypad3);
else {
typeAltCombination(keyState, Key_Keypad1, Key_Keypad4, Key_Keypad8);
return MACRO_NONE;
// void tapDanceAction(uint8_t tap_dance_index, KeyAddr key_addr, uint8_t tap_count,
// kaleidoscope::plugin::TapDance::ActionType tap_dance_action) {
// switch (tap_dance_index) {
// // Swedish
// case LEFT_ENCLOSURES:
// return tapDanceActionKeys(tap_count, tap_dance_action, Key_SE_LPar, Key_SE_LCB, Key_SE_LBR);
// case RIGHT_ENCLOSURES:
// return tapDanceActionKeys(tap_count, tap_dance_action, Key_SE_RPar, Key_SE_RCB, Key_SE_RBR);
// // English
// //case LEFT_ENCLOSURES:
// // return tapDanceActionKeys(tap_count, tap_dance_action, Key_LPar, Key_LCB, Key_LeftBracket);
// //case RIGHT_ENCLOSURES:
// // return tapDanceActionKeys(tap_count, tap_dance_action, Key_RPar, Key_RCB, Key_RightBracket);
// default:
// Macros.type(PSTR("error"));
// These 'solid' color effect definitions define a rainbow of
// LED color modes calibrated to draw 500mA or less on the
// Keyboardio Model 01.
static kaleidoscope::plugin::LEDSolidColor solidRed(160, 0, 0);
static kaleidoscope::plugin::LEDSolidColor solidOrange(140, 70, 0);
static kaleidoscope::plugin::LEDSolidColor solidGreen(0, 160, 0);
static kaleidoscope::plugin::LEDSolidColor solidBlue(0, 70, 130);
static kaleidoscope::plugin::LEDSolidColor solidIndigo(0, 0, 170);
static kaleidoscope::plugin::LEDSolidColor solidViolet(130, 0, 120);
/** toggleLedsOnSuspendResume toggles the LEDs off when the host goes to sleep,
* and turns them back on when it wakes up.
void toggleLedsOnSuspendResume(kaleidoscope::plugin::HostPowerManagement::Event event) {
switch (event) {
case kaleidoscope::plugin::HostPowerManagement::Suspend:
case kaleidoscope::plugin::HostPowerManagement::Sleep:
LEDControl.disable();
case kaleidoscope::plugin::HostPowerManagement::Resume:
LEDControl.enable();
/** hostPowerManagementEventHandler dispatches power management events (suspend,
* resume, and sleep) to other functions that perform action based on these
* events.
void hostPowerManagementEventHandler(kaleidoscope::plugin::HostPowerManagement::Event event) {
toggleLedsOnSuspendResume(event);
/** This 'enum' is a list of all the magic combos used by the Model 01's
* firmware The names aren't particularly important. What is important is that
* each is unique.
* These are the names of your magic combos. They will be used by the
* `USE_MAGIC_COMBOS` call below.
enum {
// Toggle between Boot (6-key rollover; for BIOSes and early boot) and NKRO
// mode.
COMBO_TOGGLE_NKRO_MODE,
// Enter test mode
COMBO_ENTER_TEST_MODE
/** Wrappers, to be used by MagicCombo. **/
* This simply toggles the keyboard protocol via USBQuirks, and wraps it within
* a function with an unused argument, to match what MagicCombo expects.
static void toggleKeyboardProtocol(uint8_t combo_index) {
USBQuirks.toggleKeyboardProtocol();
* Toggles between using the built-in keymap, and the EEPROM-stored one.
static void toggleKeymapSource(uint8_t combo_index) {
if (Layer.getKey == Layer.getKeyFromPROGMEM) {
Layer.getKey = EEPROMKeymap.getKey;
} else {
Layer.getKey = Layer.getKeyFromPROGMEM;
* This enters the hardware test mode
static void enterHardwareTestMode(uint8_t combo_index) {
HardwareTestMode.runTests();
/** Magic combo list, a list of key combo and action pairs the firmware should
* recognise.
// First, tell Kaleidoscope which plugins you want to use.
KALEIDOSCOPE_INIT_PLUGINS(
// Chrysalis plugins
// The EEPROMSettings & EEPROMKeymap plugins make it possible to have an
// editable keymap in EEPROM.
EEPROMSettings,
EEPROMKeymap,
// Focus allows bi-directional communication with the host, and is the
// interface through which the keymap in EEPROM can be edited.
Focus,
// FocusSettingsCommand adds a few Focus commands, intended to aid in
// changing some settings of the keyboard, such as the default layer (via the
// `settings.defaultLayer` command)
FocusSettingsCommand,
// FocusEEPROMCommand adds a set of Focus commands, which are very helpful in
// both debugging, and in backing up one's EEPROM contents.
FocusEEPROMCommand,
// The FirmwareVersion plugin lets Chrysalis query the version of the firmware
// programmatically.
//FirmwareVersion,
// The LayerNames plugin allows Chrysalis to display - and edit - custom layer
// names, to be shown instead of the default indexes.
//LayerNames,
// Enables setting, saving (via Chrysalis), and restoring (on boot) the
// default LED mode.
//DefaultLEDModeConfig,
// Enables controlling (and saving) the brightness of the LEDs via Focus.
//LEDBrightnessConfig,
// Keystroke-handling plugins
// The Qukeys plugin enables the "Secondary action" functionality in
// Chrysalis. Keys with secondary actions will have their primary action
// performed when tapped, but the secondary action when held.
//Qukeys,
// SpaceCadet can turn your shifts into parens on tap, while keeping them as
// Shifts when held. SpaceCadetConfig lets Chrysalis configure some aspects of
// the plugin.
//SpaceCadet,
//SpaceCadetConfig,
// Enables the "Sticky" behavior for modifiers, and the "Layer shift when
// held" functionality for layer keys.
OneShot,
//OneShotConfig,
EscapeOneShot,
//EscapeOneShotConfig,
Macros,
// Enables dynamic, Chrysalis-editable macros.
DynamicMacros,
MouseKeys,
//MouseKeysConfig,
// The MagicCombo plugin lets you use key combinations to trigger custom
// actions - a bit like Macros, but triggered by pressing multiple keys at the
// same time.
MagicCombo,
// LED mode plugins
// The boot greeting effect pulses the LED button for 10 seconds after the
// keyboard is first connected
BootGreetingEffect,
LEDControl,
LEDOff,
// The rainbow effect changes the color of all of the keyboard's keys at the same time
//LEDRainbowEffect,
LEDRainbowWaveEffect,
//LEDChaseEffect,
//solidRed,
//solidOrange,
//solidGreen,
//solidBlue,
//solidIndigo,
//solidViolet,
//LEDBreatheEffect,
// The AlphaSquare effect prints each character you type, using your
// keyboard's LEDs as a display
//AlphaSquareEffect,
//StalkerEffect,
// The LED Palette Theme plugin provides a shared palette for other plugins,
// like Colormap below
//LEDPaletteTheme,
// The Colormap effect makes it possible to set up per-layer colormaps
//ColormapEffect,
// The numpad plugin is responsible for lighting up the 'numpad' mode
// with a custom LED effect
//NumPad,
// The HostPowerManagement plugin allows us to turn LEDs off when then host
// goes to sleep, and resume them when it wakes up.
HostPowerManagement,
// Turns LEDs off after a configurable amount of idle time.
IdleLEDs,
PersistentIdleLEDs,
TapDance,
ActiveModColorEffect,
// Miscellaneous plugins
// The USBQuirks plugin lets you do some things with USB that we aren't
// comfortable - or able - to do automatically, but can be useful
// nevertheless. Such as toggling the key report protocol between Boot (used
// by BIOSes) and Report (NKRO).
USBQuirks,
// The hardware test mode, which can be invoked by tapping Prog, LED and the
// left Fn button at the same time.
HardwareTestMode //,
void setup() {
Kaleidoscope.setup();
// Set the hue of the boot greeting effect to something that will result in a
// nice green color.
BootGreetingEffect.hue = 85;
//NumPad.numPadLayer = NUMPAD;
//AlphaSquare.color = CRGB(255, 0, 0);
// Set the rainbow effects to be reasonably bright, but low enough
// to mitigate audible noise in some environments.
LEDRainbowEffect.brightness(170);
LEDRainbowWaveEffect.brightness(160);
// Set the action key the test mode should listen for to Left Fn
HardwareTestMode.setActionKey(R3C6);
// The LED Stalker mode has a few effects. The one we like is called
// 'BlazingTrail'. For details on other options, see
// https://github.com/keyboardio/Kaleidoscope/blob/master/docs/plugins/LED-Stalker.md
//StalkerEffect.variant = STALKER(BlazingTrail);
TapDance.time_out = 300;
//OneShot.time_out = 1000;
OneShot.setTimeout(1000);
//IdleLEDs.setIdleTimeoutSeconds(300);
//ActiveModColorEffect.highlight_color = CRGB(0x00, 0xff, 0x00);
//ActiveModColorEffect.sticky_color = CRGB(0xff, 0x80, 0x00);
ActiveModColorEffect.setHighlightColor(CRGB(0x00, 0xff, 0x00));
//ActiveModColorEffect.setStickyColor(CRGB(0xff, 0x80, 0x00));
ActiveModColorEffect.setOnestickyColor(CRGB(0xff, 0x80, 0x00));
// To make the keymap editable without flashing new firmware, we store
// additional layers in EEPROM. For now, we reserve space for eight layers. If
// one wants to use these layers, just set the default layer to one in EEPROM,
// by using the `settings.defaultLayer` Focus command, or by using the
// `keymap.onlyCustom` command to use EEPROM layers only.
EEPROMKeymap.setup(8);
// We need to tell the Colormap plugin how many layers we want to have custom
// maps for. To make things simple, we set it to eight layers, which is how
// many editable layers we have (see above).
//ColormapEffect.max_layers(8);
// For Dynamic Macros, we need to reserve storage space for the editable
// macros. A kilobyte is a reasonable default.
DynamicMacros.reserve_storage(1024);
// If there's a default layer set in EEPROM, we should set that as the default
// here.
Layer.move(EEPROMSettings.default_layer());
// To avoid any surprises, SpaceCadet is turned off by default. However, it
// can be permanently enabled via Chrysalis, so we should only disable it if
// no configuration exists.
//SpaceCadetConfig.disableSpaceCadetIfUnconfigured();
// Editable layer names are stored in EEPROM too, and we reserve 16 bytes per
// layer for them. We need one extra byte per layer for bookkeeping, so we
// reserve 17 / layer in total.
//LayerNames.reserve_storage(17 * 8);
// Unless configured otherwise with Chrysalis, we want to make sure that the
// firmware starts with LED effects off. This avoids over-taxing devices that
// don't have a lot of power to share with USB devices
//DefaultLEDModeConfig.activateLEDModeIfUnconfigured(&LEDOff);
* As you might expect, it runs in a loop, never exiting.
* For Kaleidoscope-based keyboard firmware, you usually just want to
* call Kaleidoscope.loop(); and not do anything custom here.
void loop() {
