I want to use shapeshifter to map the US number / shifted number layout onto a Swiss-german layout. When I press shift + number, the first time that the number is pressed, the original Swiss-german mapping is printed, then the new shapeshifted one. Subsequent presses are the new mapping. See below (note that the spaces are for clarity, they are not printed):
1 +! !!!
2 ”+ +++++
3 + +++++
4 ç+ +++++
5 % %%%%
6 &+ +++++
7 /& &&&&
8 ( *****
9 )( (((((((
0 =) )))))))
This is my firmware:
// -*- mode: c++ -*-
// Copyright 2016 Keyboardio, inc. <jesse@keyboard.io>
#ifndef BUILD_INFORMATION
#define BUILD_INFORMATION "locally built"
#endif
* These #include directives pull in the Kaleidoscope firmware core,
* as well as the Kaleidoscope plugins we use in the Model 01's firmware
// The Kaleidoscope core
#include "Kaleidoscope.h"
#include <Kaleidoscope-ShapeShifter.h>
// Support for storing the keymap in EEPROM
#include "Kaleidoscope-EEPROM-Settings.h"
#include "Kaleidoscope-EEPROM-Keymap.h"
// Support for communicating with the host via a simple Serial protocol
#include "Kaleidoscope-FocusSerial.h"
// Support for macros
// Support for "Numpad" mode, which is mostly just the Numpad specific LED mode
#include "Kaleidoscope-NumPad.h"
// Support for the "Boot greeting" effect, which pulses the 'LED' button for 10s
// Support for LED modes that set all LEDs to a single color
// Support for an LED mode that makes all the LEDs 'breathe'
#include "Kaleidoscope-LEDEffect-Breathe.h"
#include "Kaleidoscope-LEDEffect-Chase.h"
// Support for LED modes that pulse the keyboard's LED in a rainbow pattern
// Support for an LED mode that prints the keys you press in letters 4px high
#include "Kaleidoscope-LED-AlphaSquare.h"
// Support for an LED mode that lets one configure per-layer color maps
#include "Kaleidoscope-Colormap.h"
// Support for Keyboardio's internal keyboard testing mode
#include "Kaleidoscope-HardwareTestMode.h"
// Support for host power management (suspend & wakeup)
#include "Kaleidoscope-HostPowerManagement.h"
// Support for magic combos (key chords that trigger an action)
#include "Kaleidoscope-MagicCombo.h"
// Support for USB quirks, like changing the key state report protocol
#include "Kaleidoscope-USB-Quirks.h"
// Experimental plugins
#include "Kaleidoscope-OneShot.h"
#include "Kaleidoscope-Qukeys.h"
#include "Kaleidoscope-SpaceCadet.h"
#include "Kaleidoscope-LED-ActiveModColor.h"
#include "Kaleidoscope-LED-Palette-Theme.h"
/** This 'enum' is a list of all the macros used by the Model 01's firmware
* The names aren't particularly important. What is important is that each
* is unique.
* These are the names of your macros. They'll be used in two places.
* The first is in your keymap definitions. There, you'll use the syntax
* `M(MACRO_NAME)` to mark a specific keymap position as triggering `MACRO_NAME`
* The second usage is in the 'switch' statement in the `macroAction` function.
* That switch statement actually runs the code associated with a macro when
* a macro key is pressed.
enum { MACRO_VERSION_INFO,
MACRO_ANY
/** The Model 01's key layouts are defined as 'keymaps'. By default, there are three
* keymaps: The standard QWERTY keymap, the "Function layer" keymap and the "Numpad"
* keymap.
* Each keymap is defined as a list using the 'KEYMAP_STACKED' macro, built
* of first the left hand's layout, followed by the right hand's layout.
* Keymaps typically consist mostly of `Key_` definitions. There are many, many keys
* defined as part of the USB HID Keyboard specification. You can find the names
* (if not yet the explanations) for all the standard `Key_` defintions offered by
* Kaleidoscope in these files:
* https://github.com/keyboardio/Kaleidoscope/blob/master/src/key_defs_keyboard.h
* https://github.com/keyboardio/Kaleidoscope/blob/master/src/key_defs_consumerctl.h
* https://github.com/keyboardio/Kaleidoscope/blob/master/src/key_defs_sysctl.h
* https://github.com/keyboardio/Kaleidoscope/blob/master/src/key_defs_keymaps.h
* Additional things that should be documented here include
* using ___ to let keypresses fall through to the previously active layer
* using XXX to mark a keyswitch as 'blocked' on this layer
* using ShiftToLayer() and LockLayer() keys to change the active keymap.
* keeping NUM and FN consistent and accessible on all layers
* The PROG key is special, since it is how you indicate to the board that you
* want to flash the firmware. However, it can be remapped to a regular key.
* When the keyboard boots, it first looks to see whether the PROG key is held
* down; if it is, it simply awaits further flashing instructions. If it is
* not, it continues loading the rest of the firmware and the keyboard
* functions normally, with whatever binding you have set to PROG. More detail
* here: https://community.keyboard.io/t/how-the-prog-key-gets-you-into-the-bootloader/506/8
* The "keymaps" data structure is a list of the keymaps compiled into the firmware.
* The order of keymaps in the list is important, as the ShiftToLayer(#) and LockLayer(#)
* macros switch to key layers based on this list.
* A key defined as 'ShiftToLayer(FUNCTION)' will switch to FUNCTION while held.
* Similarly, a key defined as 'LockLayer(NUMPAD)' will switch to NUMPAD when tapped.
* Layers are "0-indexed" -- That is the first one is layer 0. The second one is layer 1.
* The third one is layer 2.
* This 'enum' lets us use names like QWERTY, FUNCTION, and NUMPAD in place of
* the numbers 0, 1 and 2.
enum { PRIMARY, NUMPAD, FUNCTION }; // layers
* To change your keyboard's layout from QWERTY to DVORAK or COLEMAK, comment out the line
* #define PRIMARY_KEYMAP_QWERTY
* by changing it to
* // #define PRIMARY_KEYMAP_QWERTY
* Then uncomment the line corresponding to the layout you want to use.
// #define PRIMARY_KEYMAP_COLEMAK
// #define PRIMARY_KEYMAP_DVORAK
// #define PRIMARY_KEYMAP_CUSTOM
/* This comment temporarily turns off astyle's indent enforcement
* so we can make the keymaps actually resemble the physical key layout better
// *INDENT-OFF*
KEYMAPS(
#if defined (PRIMARY_KEYMAP_QWERTY)
[PRIMARY] = KEYMAP_STACKED
(___, Key_1, Key_2, Key_3, Key_4, Key_5, Key_LEDEffectNext,
Key_PageUp, Key_A, Key_S, Key_D, Key_F, Key_G,
ShiftToLayer(FUNCTION),
M(MACRO_ANY), Key_6, Key_7, Key_8, Key_9, Key_0, LockLayer(NUMPAD),
Key_Enter, Key_Y, Key_U, Key_I, Key_O, Key_P, Key_Equals,
Key_H, Key_J, Key_K, Key_L, Key_Semicolon, Key_Quote,
Key_RightAlt, Key_N, Key_M, Key_Comma, Key_Period, Key_Slash, Key_Minus,
ShiftToLayer(FUNCTION)),
#elif defined (PRIMARY_KEYMAP_DVORAK)
Key_Backtick, Key_Quote, Key_Comma, Key_Period, Key_P, Key_Y, Key_Tab,
Key_PageUp, Key_A, Key_O, Key_E, Key_U, Key_I,
Key_PageDown, Key_Semicolon, Key_Q, Key_J, Key_K, Key_X, Key_Escape,
Key_Enter, Key_F, Key_G, Key_C, Key_R, Key_L, Key_Slash,
Key_D, Key_H, Key_T, Key_N, Key_S, Key_Minus,
Key_RightAlt, Key_B, Key_M, Key_W, Key_V, Key_Z, Key_Equals,
#elif defined (PRIMARY_KEYMAP_COLEMAK)
Key_Backtick, Key_Q, Key_W, Key_F, Key_P, Key_G, Key_Tab,
Key_PageUp, Key_A, Key_R, Key_S, Key_T, Key_D,
Key_Enter, Key_J, Key_L, Key_U, Key_Y, Key_Semicolon, Key_Equals,
Key_H, Key_N, Key_E, Key_I, Key_O, Key_Quote,
Key_RightAlt, Key_K, Key_M, Key_Comma, Key_Period, Key_Slash, Key_Minus,
#elif defined (PRIMARY_KEYMAP_CUSTOM)
// Edit this keymap to make a custom layout
#else
#error "No default keymap defined. You should make sure that you have a line like '#define PRIMARY_KEYMAP_QWERTY' in your sketch"
#endif
[NUMPAD] = KEYMAP_STACKED
___, ___, ___, ___,
___,
M(MACRO_VERSION_INFO), ___, Key_7, Key_8, Key_9, Key_KeypadSubtract, ___,
___, ___, Key_4, Key_5, Key_6, Key_KeypadAdd, ___,
___, Key_1, Key_2, Key_3, Key_Equals, ___,
___, ___, Key_0, Key_Period, Key_KeypadMultiply, Key_KeypadDivide, Key_Enter,
___, ___, ___, ___,
___),
[FUNCTION] = KEYMAP_STACKED
(___, Key_F1, Key_F2, Key_F3, Key_F4, Key_F5, Key_CapsLock,
Key_Tab, ___, Key_mouseUp, ___, Key_mouseBtnR, Key_mouseWarpEnd, Key_mouseWarpNE,
Key_Home, Key_mouseL, Key_mouseDn, Key_mouseR, Key_mouseBtnL, Key_mouseWarpNW,
Key_End, Key_PrintScreen, Key_Insert, ___, Key_mouseBtnM, Key_mouseWarpSW, Key_mouseWarpSE,
___, Key_Delete, ___, ___,
___,
Consumer_ScanPreviousTrack, Key_F6, Key_F7, Key_F8, Key_F9, Key_F10, Key_F11,
Consumer_PlaySlashPause, Consumer_ScanNextTrack, Key_LeftCurlyBracket, Key_RightCurlyBracket, Key_LeftBracket, Key_RightBracket, Key_F12,
Key_LeftArrow, Key_DownArrow, Key_UpArrow, Key_RightArrow, ___, ___,
Key_PcApplication, Consumer_Mute, Consumer_VolumeDecrement, Consumer_VolumeIncrement, ___, Key_Backslash, Key_Pipe,
___, ___, Key_Enter, ___,
___)
) // KEYMAPS(
/* Re-enable astyle's indent enforcement */
// *INDENT-ON*
/** versionInfoMacro handles the 'firmware version info' macro
* When a key bound to the macro is pressed, this macro
* prints out the firmware build information as virtual keystrokes
static void versionInfoMacro(uint8_t keyState) {
if (keyToggledOn(keyState)) {
Macros.type(PSTR("Keyboardio Model 01 - Kaleidoscope "));
/** anyKeyMacro is used to provide the functionality of the 'Any' key.
* When the 'any key' macro is toggled on, a random alphanumeric key is
* selected. While the key is held, the function generates a synthetic
* keypress event repeating that randomly selected key.
static void anyKeyMacro(uint8_t keyState) {
static Key lastKey;
bool toggledOn = false;
lastKey.keyCode = Key_A.keyCode + (uint8_t)(millis() % 36);
toggledOn = true;
if (keyIsPressed(keyState))
kaleidoscope::hid::pressKey(lastKey, toggledOn);
switch (macroIndex) {
case MACRO_VERSION_INFO:
versionInfoMacro(keyState);
case MACRO_ANY:
anyKeyMacro(keyState);
return MACRO_NONE;
static const kaleidoscope::plugin::ShapeShifter::dictionary_t shape_shift_dictionary[] PROGMEM = {
{Key_0, Key_9}, //9
{Key_1, Key_RightBracket}, // ]
{Key_2, Key_1}, //alt gr g
{Key_3, Key_1}, //alt gr 3
{Key_4, Key_1}, // \ inverted
{Key_5, Key_5}, // no mapping
{Key_6, Key_1}, // map to ] inverted
{Key_7, Key_6}, // 6
{Key_8, Key_3}, // 3
{Key_9, Key_8}, // 8
//todo remap all of the number keys..and the punctuation keys.
{Key_NoKey, Key_NoKey},
// These 'solid' color effect definitions define a rainbow of
// LED color modes calibrated to draw 500mA or less on the
// Keyboardio Model 01.
static kaleidoscope::plugin::LEDSolidColor solidRed(160, 0, 0);
static kaleidoscope::plugin::LEDSolidColor solidOrange(140, 70, 0);
static kaleidoscope::plugin::LEDSolidColor solidYellow(130, 100, 0);
static kaleidoscope::plugin::LEDSolidColor solidGreen(0, 160, 0);
static kaleidoscope::plugin::LEDSolidColor solidBlue(0, 70, 130);
static kaleidoscope::plugin::LEDSolidColor solidIndigo(0, 0, 170);
static kaleidoscope::plugin::LEDSolidColor solidViolet(130, 0, 120);
/** toggleLedsOnSuspendResume toggles the LEDs off when the host goes to sleep,
* and turns them back on when it wakes up.
void toggleLedsOnSuspendResume(kaleidoscope::plugin::HostPowerManagement::Event event) {
switch (event) {
case kaleidoscope::plugin::HostPowerManagement::Suspend:
LEDControl.set_all_leds_to({0, 0, 0});
LEDControl.syncLeds();
LEDControl.paused = true;
case kaleidoscope::plugin::HostPowerManagement::Resume:
LEDControl.paused = false;
LEDControl.refreshAll();
case kaleidoscope::plugin::HostPowerManagement::Sleep:
/** hostPowerManagementEventHandler dispatches power management events (suspend,
* resume, and sleep) to other functions that perform action based on these
* events.
void hostPowerManagementEventHandler(kaleidoscope::plugin::HostPowerManagement::Event event) {
toggleLedsOnSuspendResume(event);
/** A tiny wrapper, to be used by MagicCombo.
* This simply toggles the keyboard protocol via USBQuirks, and wraps it within
* a function with an unused argument, to match what MagicCombo expects.
static void toggleKeyboardProtocol(uint8_t combo_index) {
USBQuirks.toggleKeyboardProtocol();
/** Magic combo list, a list of key combo and action pairs the firmware should
* recognise.
USE_MAGIC_COMBOS({.action = toggleKeyboardProtocol,
// Left Fn + Esc + Shift
.keys = { R3C6, R2C6, R3C7 }
// First, tell Kaleidoscope which plugins you want to use.
KALEIDOSCOPE_INIT_PLUGINS(
// The EEPROMSettings & EEPROMKeymap plugins make it possible to have an
// editable keymap in EEPROM.
EEPROMSettings,
EEPROMKeymap,
// Focus allows bi-directional communication with the host, and is the
// interface through which the keymap in EEPROM can be edited.
Focus,
// FocusSettingsCommand adds a few Focus commands, intended to aid in
// changing some settings of the keyboard, such as the default layer (via the
// `settings.defaultLayer` command)
FocusSettingsCommand,
// FocusEEPROMCommand adds a set of Focus commands, which are very helpful in
// both debugging, and in backing up one's EEPROM contents.
FocusEEPROMCommand,
// The boot greeting effect pulses the LED button for 10 seconds after the
// keyboard is first connected
BootGreetingEffect,
// The hardware test mode, which can be invoked by tapping Prog, LED and the
// left Fn button at the same time.
HardwareTestMode,
LEDControl,
ActiveModColorEffect,
OneShot,
Qukeys,
SpaceCadet,
LEDOff,
// The rainbow effect changes the color of all of the keyboard's keys at the same time
LEDRainbowEffect,
LEDRainbowWaveEffect,
LEDChaseEffect,
//solidRed, solidOrange, solidYellow, solidGreen, solidBlue, solidIndigo, solidViolet,
LEDBreatheEffect,
// The AlphaSquare effect prints each character you type, using your
// keyboard's LEDs as a display
AlphaSquareEffect,
StalkerEffect,
// The Colormap effect makes it possible to set up per-layer colormaps
ColormapEffect,
// The numpad plugin is responsible for lighting up the 'numpad' mode
// with a custom LED effect
NumPad,
Macros,
MouseKeys,
// The HostPowerManagement plugin allows us to turn LEDs off when then host
// goes to sleep, and resume them when it wakes up.
HostPowerManagement,
// The MagicCombo plugin lets you use key combinations to trigger custom
// actions - a bit like Macros, but triggered by pressing multiple keys at the
// same time.
MagicCombo,
// The USBQuirks plugin lets you do some things with USB that we aren't
// comfortable - or able - to do automatically, but can be useful
// nevertheless. Such as toggling the key report protocol between Boot (used
// by BIOSes) and Report (NKRO).
USBQuirks,
LEDPaletteTheme,
ShapeShifter
void setup() {
Kaleidoscope.setup();
NumPad.numPadLayer = NUMPAD;
AlphaSquare.color = CRGB(255, 0, 0);
LEDRainbowEffect.brightness(150);
LEDRainbowWaveEffect.brightness(150);
// The LED Stalker mode has a few effects. The one we like is called
// 'BlazingTrail'. For details on other options, see
// https://github.com/keyboardio/Kaleidoscope/blob/master/doc/plugin/LED-Stalker.md
StalkerEffect.variant = STALKER(BlazingTrail);
// We want to make sure that the firmware starts with LED effects off
// This avoids over-taxing devices that don't have a lot of power to share
// with USB devices
LEDOff.activate();
// To make the keymap editable without flashing new firmware, we store
// additional layers in EEPROM. For now, we reserve space for five layers. If
// one wants to use these layers, just set the default layer to one in EEPROM,
// by using the `settings.defaultLayer` Focus command, or by using the
// `keymap.onlyCustom` command to use EEPROM layers only.
EEPROMKeymap.setup(5);
// We need to tell the Colormap plugin how many layers we want to have custom
// maps for. To make things simple, we set it to five layers, which is how
// many editable layers we have (see above).
ColormapEffect.max_layers(5);
ShapeShifter.dictionary = shape_shift_dictionary;
* As you might expect, it runs in a loop, never exiting.
* For Kaleidoscope-based keyboard firmware, you usually just want to
* call Kaleidoscope.loop(); and not do anything custom here.
void loop() {
