Dedicated brackets key
I have started modifying my Model 01 for my preferences and I have been making good progress.
Here is what I have done so far:
  • Moved cursor keys to UJHL (the wsad pattern is a habit and less work for pinky)
  • Moved mouse keys to EDSF - for the same reason
  • Mouse warp are on WRXV
Those are just examples - I’d be happy to share if anyone is interested.
I do a lot of java programming, so a dedicated key for brackets would be most welcome.
I mapped led { and any to }
But I can’t figure out how to map shift+led to [ and shift+fn+led to (
I want something like this: 12
I can see that @algernon has a brackets key like I want. But honestly that codebase is really scary. I it hard to figure out what I need to do to get the bracket key with the minimum number of plugins. https://github.com/algernon/Model01-sketch
A releated item on my TODO list is mapping the extra danish wovels æøå and shifted ÆØÅ.
But I hope that mapping those will be some of the same tricks as I need for the bracket keys?
I can’t change the layout of my windows computer, so I need the hardware to do the work.
Some of my questions is also asked in this thread: Remapping keys?
But I need a little more help than that thread provides.
hmm.
I’m liking that remapped EDSF thing.
This is my current layout for reference:
  [QWERTY] = KEYMAP_STACKED
  (___,          Key_1, Key_2, Key_3, Key_4, Key_5, Key_LeftCurlyBracket,
   Key_PageUp,   Key_A, Key_S, Key_D, Key_F, Key_G,
   ShiftToLayer(FUNCTION),
   Key_RightCurlyBracket,  Key_6, Key_7, Key_8,     Key_9,         Key_0,         Key_KeypadNumLock,
   Key_Enter,     Key_Y, Key_U, Key_I,     Key_O,         Key_P,         Key_Equals,
   Key_RightAlt,  Key_N, Key_M, Key_Comma, Key_Period,    Key_Slash,     Key_Minus,
   ShiftToLayer(FUNCTION)),
  [FUNCTION] =  KEYMAP_STACKED
  (___,      Key_F1,           Key_F2,          Key_F3,           Key_F4,          Key_F5,           XXX,
   Key_Tab,  Key_mouseWarpEnd, Key_mouseWarpNW, Key_mouseUp,      Key_mouseWarpNE, Key_mouseBtnL,    Key_mouseScrollUp,
   Key_Home, Key_Insert,       Key_mouseL,      Key_mouseDn,      Key_mouseR,      Key_mouseBtnR,
   Key_End,  Key_PrintScreen,  Key_mouseWarpSW, Key_mouseWarpEnd, Key_mouseWarpSE, Key_mouseBtnM,    Key_mouseScrollDn,
   ___, Key_Delete, ___, ___,
   ___,
   Consumer_PlaySlashPause,    Key_Home,               Key_UpArrow,              Key_End,                  Key_LeftBracket, Key_RightBracket, Key_F12,
                               Key_LeftArrow,          Key_DownArrow,            Key_RightArrow,           ___,             ___,              ___,
   Key_PcApplication,          Key_Mute,               Consumer_VolumeDecrement, Consumer_VolumeIncrement, ___,             Key_Backslash,    Key_Pipe,
   ___, ___, Key_Enter, ___,
   ___),
  [NUMPAD] =  KEYMAP_STACKED
  (___, ___, ___, ___, ___, ___, Key_LEDEffectNext,
   ___, ___, ___, ___, ___, ___, ___,
   ___, ___, ___, ___,
   ___,
   M(MACRO_VERSION_INFO),  ___, Key_Keypad7, Key_Keypad8,   Key_Keypad9,        Key_KeypadSubtract, ___,
   ___,                    ___, Key_Keypad4, Key_Keypad5,   Key_Keypad6,        Key_KeypadAdd,      ___,
                           ___, Key_Keypad1, Key_Keypad2,   Key_Keypad3,        Key_Equals,         Key_Quote,
   ___,                    ___, Key_Keypad0, Key_KeypadDot, Key_KeypadMultiply, Key_KeypadDivide,   Key_Enter,
   ___, ___, ___, ___,
   ___)
If you’d be ok with LED and Any mapped to [ and ] respectively, then you’d get { / } for free with Shift+LED and Shift+Any. Then making Shift+Fn+LED ( is as “easy” as adjusting the key on the Fn layer that’s in the LED position to read LSHIFT(Key_9). This also gets you Fn+LED as (, mind you, without the need for shift.
If you want [ and { swapped, that takes a bit more effort, and you’ll either need a macro, or the TopsyTurvy plugin.
Let me know if you want help or guidance with either of these options, and I’ll happily go into more detail.
Heh. Sorry about that! It is a complicated thing.
Thank you for the quick reply!
Your suggestion is good and very simple. I suppose I could live with that.
But since I write many more curly brackets, than square ones - and because hacking is fun - I would very much appreciate an outline of how you would go about it.
As a bonus I’d like to stack < on the key as well, if at all possible. That would be fn+shift then.
Thanks!
Mhm, so LED becomes {, Shift+LED becomes [, Fn+LED becomes (, and Fn+Shift+LED becomes <, right?
This will be a nice chain to implement! We’ll do it in two steps, first the {/[ part, then the other.
For the first, we basically want to swap the effect shift has on the [ key, and we’ll use the TopsyTurvy plugin for that, which was made just for this:
#include "Kaleidoscope-TopsyTurvy.h"
void setup() {
 Kaleidoscope.use(
    // All the usual plugins
    &TopsyTurvy
And in the keymap, on the QWERTY layer, use TOPSY(LeftBracket) at the LED position, TOPSY(RightBracket) for the Any position. This should be all you need.
Do note that currently there are issues when you chord a Topsy key with a non-Topsy one. I will get around to fixing that… hopefully soon. It’s one of the nasty issues that are hard to fix well. On the flip side, it shouldn’t affect you all that much, because the brackets are rarely chorded with anything else!
Now, the second part is a bit trickier, because we want to completely replace the symbol we get when shifted. The parentheses are shifted symbols to begin with. We can’t use Topsy here, because we change the symbol, not flip shifted and non-shifted. As it happens, there is a plugin for this too! It bears the scary name of ShapeShifter. We’ll use the fact that < is a shifted symbol too, and that allows us to use the ShapeShifter plugin. What it does, is that we can tell it that if it sees a certain key chorded with Shift, it will still use Shift, but instead of pressing the original key, it will simulate another. So we’ll tell it to treat Shift+LSHIFT(9) as Shift+,. Hopefully this explanation isn’t very confusing. Reading it back… it might be…
But lets see the code, perhaps that clears things up!
#include "Kaleidoscope-ShapeShifter.h"
static const kaleidoscope::ShapeShifter::dictionary_t shape_shift_dictionary[] PROGMEM = {
 {LSHIFT(Key_9), Key_Comma},
 {LSHIFT(Key_0), Key_Period},
 {Key_NoKey, Key_NoKey},
void setup() {
  Kaleidoscope.use(..., &ShapeShifter);
  ShapeShifter.dictionary = shapeShiftDictionary;
And on the FUNCTION layer, use LSHIFT(Key_9) for the LED position, and LSHIFT(Key_0) for Any.
You’ll lose the Consumer_ScanPreviousTrack key though, because that’s at the Any position on the FUNCTION layer, so you may want to move that somewhere else.
Hope this helps, and I hope that neither plugin is too buggy. I… haven’t tested them as much as I wanted to.
Ok. Got it :slight_smile:
I’ll try it out tonight and get back with either a eureka or more questions :wink:
@Jennigma - This post of @algernon’s is probably worth lifting io its own tutorial.
I think @algernon is actually using TapDance for his brackets. Based on the number of times he taps that key in your image, he gets a different type of bracket. I plan on using TapDance for brackets as well.
These are exciting times.
Edit: by the way, who came up with all the awesome and cute plugin names?
I came up with some of them, @jesse came up with others, and for some we put our heads together to name.
Ok. I have tested it out.
Implemented code as shown above. Only minor quirk was that you define the shapeshift dictionary as shape_shift_dictionary, but refer to it as shapeShiftDictionary.
So now:
led = {
any = }
fn + shift + led = <
fn + shift + any = >
BUT
shift + led = [[[[[[[[[[[[[[[[[[[[[
shift + any = ]]]]]]]]]]]]]]]]]]]]]]]]
fn + led = (,(,(,(,(,(,(,(,(,(,(,(,(,(
fn + any = ).).).).).).).).
So I am thinking that maybe - just maybe - I can settle for a less advanced layout for now :wink:
However I’d be happy if you would treat this as a bug report and take a look at it when you get a chance.
Or maybe there is another approach? A macro perhaps?
// -*- mode: c++ -*-
// Copyright 2016 Keyboardio, inc. <jesse@keyboard.io>
#ifndef BUILD_INFORMATION
#define BUILD_INFORMATION "locally built"
#endif
 * These #include directives pull in the Kaleidoscope firmware core,
 * as well as the Kaleidoscope plugins we use in the Model 01's firmware
// The Kaleidoscope core
#include "Kaleidoscope.h"
// Support for macros
// Support for "Numlock" mode, which is mostly just the Numlock specific LED mode
#include "Kaleidoscope-Numlock.h"
// Support for an "LED off mode"
#include "LED-Off.h"
// Support for the "Boot greeting" effect, which pulses the 'LED' button for 10s
// Support for LED modes that set all LEDs to a single color
// Support for an LED mode that makes all the LEDs 'breathe'
#include "Kaleidoscope-LEDEffect-Breathe.h"
#include "Kaleidoscope-LEDEffect-Chase.h"
// Support for LED modes that pulse the keyboard's LED in a rainbow pattern
// Support for an LED mode that prints the keys you press in letters 4px high
#include "Kaleidoscope-LED-AlphaSquare.h"
// Support for Keyboardio's internal keyboard testing mode
#include "Kaleidoscope-Model01-TestMode.h"
// Support for swapping shifts effects on a key
// Change symbols for keys
/** This 'enum' is a list of all the macros used by the Model 01's firmware
  * The names aren't particularly important. What is important is that each
  * is unique.
  * These are the names of your macros. They'll be used in two places.
  * The first is in your keymap definitions. There, you'll use the syntax
  * `M(MACRO_NAME)` to mark a specific keymap position as triggering `MACRO_NAME`
  * The second usage is in the 'switch' statement in the `macroAction` function.
  * That switch statement actually runs the code associated with a macro when
  * a macro key is pressed.
enum { MACRO_VERSION_INFO,
       MACRO_ANY
/** The Model 01's key layouts are defined as 'keymaps'. By default, there are three
  * keymaps: The standard QWERTY keymap, the "Function layer" keymap and the "Numpad"
  * keymap.
  * Each keymap is defined as a list using the 'KEYMAP_STACKED' macro, built
  * of first the left hand's layout, followed by the right hand's layout.
  * Keymaps typically consist mostly of `Key_` definitions. There are many, many keys
  * defined as part of the USB HID Keyboard specification. You can find the names
  * (if not yet the explanations) for all the standard `Key_` defintions offered by
  * Kaleidoscope in these files:
  *    https://github.com/keyboardio/Kaleidoscope/blob/master/src/key_defs_keyboard.h
  *    https://github.com/keyboardio/Kaleidoscope/blob/master/src/key_defs_consumerctl.h
  *    https://github.com/keyboardio/Kaleidoscope/blob/master/src/key_defs_sysctl.h
  *    https://github.com/keyboardio/Kaleidoscope/blob/master/src/key_defs_keymaps.h
  * Additional things that should be documented here include
  *   using ___ to let keypresses fall through to the previously active layer
  *   using XXX to mark a keyswitch as 'blocked' on this layer
  *   using ShiftToLayer() and LockLayer() keys to change the active keymap.
  *   the special nature of the PROG key
  *   keeping NUM and FN consistent and accessible on all layers
  * The "keymaps" data structure is a list of the keymaps compiled into the firmware.
  * The order of keymaps in the list is important, as the ShiftToLayer(#) and LockLayer(#)
  * macros switch to key layers based on this list.
  * A key defined as 'ShiftToLayer(FUNCTION)' will switch to FUNCTION while held.
  * Similarly, a key defined as 'LockLayer(NUMPAD)' will switch to NUMPAD when tapped.
  * Layers are "0-indexed" -- That is the first one is layer 0. The second one is layer 1.
  * The third one is layer 2.
  * This 'enum' lets us use names like QWERTY, FUNCTION, and NUMPAD in place of
  * the numbers 0, 1 and 2.
enum { QWERTY, FUNCTION, NUMPAD }; // layers
/* This comment temporarily turns off astyle's indent enforcement
 *   so we can make the keymaps actually resemble the physical key layout better
// *INDENT-OFF*
  (___,          Key_1, Key_2, Key_3, Key_4, Key_5, TOPSY(LeftBracket),
   TOPSY(RightBracket),  Key_6, Key_7, Key_8,     Key_9,         Key_0,         Key_KeypadNumLock,
  (___,      Key_F1,           Key_F2,          Key_F3,           Key_F4,          Key_F5,           LSHIFT(Key_9),
   ___,
   LSHIFT(Key_0),              Key_F6,                 Key_F7,                   Key_F8,                   Key_F9,          Key_F10,          Key_F11,
   ___),
   ___, ___, ___, ___,
   ___,
   ___, ___, ___, ___,
   ___)
// https://community.keyboard.io/t/dedicated-brackets-key/534/6
/* Re-enable astyle's indent enforcement */
// *INDENT-ON*
/** versionInfoMacro handles the 'firmware version info' macro
 *  When a key bound to the macro is pressed, this macro
 *  prints out the firmware build information as virtual keystrokes
static void versionInfoMacro(uint8_t keyState) {
  if (keyToggledOn(keyState)) {
    Macros.type(PSTR("Keyboardio Model 01 - Kaleidoscope "));
/** anyKeyMacro is used to provide the functionality of the 'Any' key.
 * When the 'any key' macro is toggled on, a random alphanumeric key is
 * selected. While the key is held, the function generates a synthetic
 * keypress event repeating that randomly selected key.
static void anyKeyMacro(uint8_t keyState) {
  static Key lastKey;
    lastKey.keyCode = Key_A.keyCode + (uint8_t)(millis() % 36);
  if (keyIsPressed(keyState))
    kaleidoscope::hid::pressKey(lastKey);
  switch (macroIndex) {
  case MACRO_VERSION_INFO:
    versionInfoMacro(keyState);
  case MACRO_ANY:
    anyKeyMacro(keyState);
  return MACRO_NONE;
// These 'solid' color effect definitions define a rainbow of
// LED color modes calibrated to draw 500mA or less on the
// Keyboardio Model 01.
static kaleidoscope::LEDSolidColor solidRed(160, 0, 0);
static kaleidoscope::LEDSolidColor solidOrange(140, 70, 0);
static kaleidoscope::LEDSolidColor solidYellow(130, 100, 0);
static kaleidoscope::LEDSolidColor solidGreen(0, 160, 0);
static kaleidoscope::LEDSolidColor solidBlue(0, 70, 130);
static kaleidoscope::LEDSolidColor solidIndigo(0, 0, 170);
static kaleidoscope::LEDSolidColor solidViolet(130, 0, 120);
void setup() {
  Kaleidoscope.setup();
  // Next, tell Kaleidoscope which plugins you want to use.
  Kaleidoscope.use(
    // The boot greeting effect pulses the LED button for 10 seconds after the keyboard is first connected
    &BootGreetingEffect,
    // The hardware test mode, which can be invoked by tapping Prog, LED and the left Fn button at the same time.
    &TestMode,
    &LEDControl,
    &LEDOff,
    // The rainbow effect changes the color of all of the keyboard's keys at the same time
    &LEDRainbowEffect,
    &LEDRainbowWaveEffect,
    &LEDChaseEffect,
    &solidRed, &solidOrange, &solidYellow, &solidGreen, &solidBlue, &solidIndigo, &solidViolet,
    &LEDBreatheEffect,
    // The AlphaSquare effect prints each character you type, using your
    // keyboard's LEDs as a display
    &AlphaSquareEffect,
    &StalkerEffect,
    // The numlock plugin is responsible for lighting up the 'numpad' mode
    // with a custom LED effect
    &NumLock,
    &Macros,
    &MouseKeys,
    // Swap the effect of the shift key
    &TopsyTurvy,
    // Change key codes for key
    &ShapeShifter
  // While we hope to improve this in the future, the NumLock plugin
  NumLock.numPadLayer = NUMPAD;
  AlphaSquare.color = { 255, 0, 0 };
  LEDRainbowEffect.brightness(150);
  LEDRainbowWaveEffect.brightness(150);
  // The LED Stalker mode has a few effects. The one we like is
  // called 'BlazingTrail'. For details on other options,
  // see https://github.com/keyboardio/Kaleidoscope-LED-Stalker
  StalkerEffect.variant = STALKER(BlazingTrail);
  // We want to make sure that the firmware starts with LED effects off
  // This avoids over-taxing devices that don't have a lot of power to share
  // with USB devices
  LEDOff.activate();
  // activeate shapeshifter
  ShapeShifter.dictionary = shape_shift_dictionary;
  * As you might expect, it runs in a loop, never exiting.
  * For Kaleidoscope-based keyboard firmware, you usually just want to
  * call Kaleidoscope.loop(); and not do anything custom here.
void loop() {
Whops, my bad, sorry!
:frowning:
I hoped that using a modifier won’t trigger this issue, but it does. I’ll try to fix it this coming weekend.
It could be done with a macro, but… that’s a bit more complicated than one would expect. If you can hold on a little bit longer, I’d try fixing the TopsyTurvy and ShapeShifter plugins first.
I brought up this exact issue in this thread. Jesse says he comfortably uses ring, pinky and middle fingers for those, on WASD! Seems totally outlandish to me! :smiling_face:
I was thinking the same about TopsyTurvy and ShapeShifter!
Those two, and TapDance, and a few others are mine. Happy to hear you like the whimsical names too :joy:
Rumor has it that for the Model 02, Plugin Naming Rights will be one of the Kickstarter reward levels.
Seriously though, they are fun names.
Working on this, but not sure how to handle the defect. Should I write as if the defect has been corrected?
I’d…probably write as if the defect had been corrected, but with a big bold note that there’s a defect? That’ll help inform users and be easiest to update when it’s resolved.
Note that @jesse has mentioned it’s binary, so next would be Model10 :wink:
But that means, with the given number of digits, there are not more than two Models to come. That’s… sad.
