Carry Sleeve/Case Recommendations
Just saw this, thanks! My cat managed to get into my walk-in closet and barf on the original box (I’m a person that keeps original packaging, so I’m bummed) so this will work great.
Has anyone found a case that can fit the keyboard along with its octopus stands?
@protoEvangelion I have the same question. If something was found, please let me know. Thanks!
I made one myself for perfect fit (that’s how much I love my keyboardio) :slight_smile: :slight_smile:
that is beautiful. I’d pay for one of those in a heartbeat!
General question: how bad is continual pressing (not too hard, but around the same pressure as normal use holding a key down) while the keyboard is in a case? I’ve found several decent laptop sleeves, some more hard-shell than others, all with soft-enough inside lining, but there seems no way to prevent keys from being pressed when in a full (not even overstuffed) backpack. Which if it happens on occasion during movement is obviously fine, but i imagine is not good for prolonged periods of time.
Would using a molded cutout like in the above example / the original box foam + felt/silk lining be the best solution to this?
