Error/warning while flashing firmware on new Model 01
Just got my new Model 01 today. I followed the instructions for installing Arduino and verifying and flashing the firmware.
When I pressed the button to verify the firmware the following warning was displayed at the bottom of the window
WARNING: Category 'Debug' in library Kaleidoscope-Hardware-Virtual is not valid. Setting to 'Uncategorized' Sketch uses 24756 bytes (86%) of program storage space. Maximum is 28672 bytes. Global variables use 1408 bytes (55%) of dynamic memory, leaving 1152 bytes for local variables. Maximum is 2560 bytes.
It seems to be the same problem as described here.
I tried holding prog, before and during both the verification and upload process and holding intermittently for 8 second periods as described in the troubleshooting page. I tried unplugging the keyboard and holding prog before plugging it in and remain holding until I press upload but still the above warning persists.
Also, when I plug in the model 01 all the LED’s turn on and work correctly. Both halves of the keyboard also work as expected but when I press the led all the keys change colour. When I press led again the left half keys change colour and the right half keys turn off completely save for the bottom right button - | which remains continuously blue. None of the keys on the right half work either and it seems the only thing I can do to get the right half working again is to unplug and plug the keyboard back in. If I press the led twice again it goes back to the same behaviour.
Any suggestions on how to fix this issue? Thanks!
As a workaround, I commented out the ‘LEDChaseEffect’ in the firmware (at around line 440) and uploaded the changes to the keyboard.
At first I moved the chase-effect to line 454, under the other LED-effects, and tried to skip it quickly when cycling through the various effects, but the right side would crash immediately upon entering the chase-effect.
By the way, does yours also sometimes, but not consistently, print a line of keystrokes on crash? My OS is on Dvorak while the keyboard is still querty; it would print along the lines of:
aoeuoucrlgf
]^X@sa^X@se^X@su^X@si^X@s^[^[[5;1~^[d^[h^[t^[n^[s^[-XJKQ:1^@^\^]Quit
Anyway, as long as you’re not addicted to the LED-chase, it should be ok :slight_smile:
Thanks, Indeed I seen your previous post in another thread explaining the work around. I only received the keyboard a few days ago and haven’t had a chance to use it after updating the firmware. I intend to try your suggestion tomorrow and report back.
I also intend to switch to Dvorak and also experiment with the oneshot setting. Indeed the LED-chase is pretty damn cool but i don’t think I’ll be losing much sleep over it if I need to comment it out :slight_smile:
Did as you instructed by commenting the LEDChaseEffect and now the keyboard seems to be working as normal. Thanks very much for the input. If I come across the printed characters on crash I will let you know. Although rather than setting my OS to dvorak I’ll be switching the keyboard keymappings to Dvorak instead so it might not be the same. Thanks again!
Just received my brand-new Model 01.
Windows 10. Did not install the Windows USB driver suggested for Windows 7/8.
Got essentially the same warning:
Sketch uses 24770 bytes (86%) of program storage space. Maximum is 28672 bytes.
Global variables use 1407 bytes (54%) of dynamic memory, leaving 1153 bytes for local variables. Maximum is 2560 bytes.
I will comment out the ‘LEDChaseEffect’ and report back.
