I’ve been stuck on my current custom firmware for the better part of a year. It is the only thing that works on both my Model 01s. Changing the sketch code and flashing makes the keyboards unresponsive. Since my custom firmware works, I’m confident it’s not a hardware issue. The only thing I have left of my current firmware is the hex file (the working sketch is lost due to my code changes), which I flash using the terminal/cmd.exe whenever my attempts to flash a new firmware fail.
I’ve tried doing everything from scratch, following the step-by-step guide. Even the default sketch/firmware results in an unresponsive keyboard. I’ve tried this on Windows 7 and Windows 10 on both my keyboards, and on different computers.
Changing the firmware used to work in the past (before the API changes I think, if that matters), though I’ve had similar issues with unresponsive keyboards if I didn’t comment out some lines of code (which I tried with the latest default firmware as well, but it didn’t help this time). It’s all so very strange.
I would appreciate it if somebody could help me out.
