At first I thought I was having this issue.
However, I have reset the keyboard to factory defaults through Chrysalis, and I am still having the same problem - I run make flash, I hit the Prog key, the lights on the keyboard flash like they’re supposed to, and afterward it seems to be running exactly the same firmware as before.
This is the output from make flash - is there perhaps a different issue? I notice that there’s no progress bar.
I’m on MacOS Big Sur
Connecting to programmer: .
Device code: 0x44
