How long should it take to flash the firmware? I had lots of trouble just getting to step 3 “flashing” and now it is just sitting there. Is this supposed to take minutes, hours, days?
I’m on a mac, using Chrome browser, with a newly arrive keyboardio model 100 and it’s stuck with a green light on the ~` key (right under PROG) and just stuck. I don’t even know if I can get out of prog mode and just use the keyboard and forget the latest firmware.
I tried a couple of browsers and tried the tricks that others have done (holding down the PROG key as you physically reconnect the cable/keyboard).
What finally seemed to work was to plug keyboard directly into the computer and not via some intermediary (like my switcher or monitor). Then chrysalis could successfully connect to the keyboard at each step and I got the firmware updated.
I’m excited to try this out.
