is there a caps lock? dumb question but can’t figure it out myself
Fn + LED, if I remember correctly.
Doesn’t look like it, on the default layer.
You should be able to customize it and add one with Kaleidoscope tho
That image is a bit outdated. Fn+LED has been CapsLock for a while, though it might be that the factory firmware does not have that change yet. In that case, flashing a new Model01-Firmware will get you a capslock.
Interesting, that’s great to know!
(I tested on my Model 01 at first, and was confirmed I didn’t have capslock…)
I should take a look at updating,
I’ve swapped numlock to capslock, and have numlock in that spot on the fn layer.
