I just acquired a Model 01. Using the Arduino IDE, I updated and flashed the latest firmware.
I cannot figure out why, but the Key_LEDEffectNext toggles caps lock.
Any advice? Thanks in advance.
The Model01-Firmware.ino file indeed shows:
#define PRIMARY_KEYMAP_QWERTY
// #define PRIMARY_KEYMAP_DVORAK
// #define PRIMARY_KEYMAP_COLEMAK
// #define PRIMARY_KEYMAP_CUSTOM
and
#if defined (PRIMARY_KEYMAP_QWERTY)
[PRIMARY] = KEYMAP_STACKED
(___, Key_1, Key_2, Key_3, Key_4, Key_5, Key_LEDEffectNext,
Key_PageUp, Key_A, Key_S, Key_D, Key_F, Key_G,
ShiftToLayer(FUNCTION),
M(MACRO_ANY), Key_6, Key_7, Key_8, Key_9, Key_0, LockLayer(NUMPAD),
Key_Enter, Key_Y, Key_U, Key_I, Key_O, Key_P, Key_Equals,
Key_H, Key_J, Key_K, Key_L, Key_Semicolon, Key_Quote,
Key_RightAlt, Key_N, Key_M, Key_Comma, Key_Period, Key_Slash, Key_Minus,
ShiftToLayer(FUNCTION)),
