kenobi
(Ben K)
February 22, 2023, 12:26am
1
I pulled and attempted to build the latest kaleidoscope, but I’m getting a bunch of build errors (attached).
build.log (8.1 KB)
I’m 98 commits ahead of the last tag:
% git describe
v1.99.7-98-g682f80ed
Should I not be pulling latest? Is there a LKG tag, or something more recent than 1.99.7 that I should be pulling?
Thanks!
-Ben
kenobi
(Ben K)
February 22, 2023, 12:27am
2
PS I was getting this error building my own image, but I’ve since gone back to building the example in examples/Devices/Keyboardio/Model100 but with the same result.
argonblue
(Taylor Yu)
February 22, 2023, 2:58am
3
You probably need to run make update in your Kaleidoscope tree to pull in the latest GD32 core.
kenobi
(Ben K)
February 27, 2023, 5:36pm
4
Sorry for the slow response. That worked, thanks! I had been running make setup thinking that would update things. Is make update documented anywhere?
