Hi there,
I have received the nice Linear-A keycaps.
But I noticed there is a misprint on my key number 4:
It is upside down.
Does anybody else has this issue.
And I cannot turn it around since then it blocks the path of key 11.
Kind regards,
Wim
For those that have blank keycaps or linear-a keycaps, it is highly likely that you will at some point jumble them or get them out of order. No need to fret, on the inside of each keycap, there is a number telling you the key order. Also, you can use the orientation of that number to help you tell up from down on the key.
It doesn’t matter which keycap set you have, from what I can tell they all seem to be numbered the same.
Here is a layout that shows the numbering scheme.
[Model 01 Keycap …
fire
April 8, 2020, 7:51pm
2
Do you mean the Linear-A symbol is upside down? Or the number 4 on the inside is upside down?
the Symbol is upside down.
Probably the same issue as here Dvorak keycap misprint?
Yes, it s the same problem. But different key.
