Model 01 switch mounting plate removal?
Is there a way to remove the switch mounting plate on the Model 01 without unsoldering all the switches (or removing all the switch upper housings, which might be easier)? This is in case I want to access the top of the circuit board. It looks like the shoulders of the switch housings that rest on top of the plate are solid blocks, not latching tabs.
I can’t help you, but I am interested in the hack you have in mind :slight_smile:
Nothing too exciting. I just want to be able to replace the ATtiny in case I manage to brick, it if I decide to try using debugWire on it.
Sadly, short of desoldering all the switches, there isn’t.
