Reset eeprom not working
Hi, I have a half working Atreus, some things work as expected but some things fail. For example, I have a dual key configured for shift/A that does not work, and have another one that is Super/V that do work… Anything I do on Chrysalys have no effect on that.
So I’ve tryed several things:
  • upgrading the firmware,
  • resetting EEPROM to the defaults,
  • downgrading the firmware
  • compiling the firmware,
  • flashing the firmware from Chrysallys and from the commandline,
  • setting the “erase everything on the keyboard” on flash
  • plugin the keyboard on bootloader mode and flashing from there on chrysalys.
  • sending `eeprom.erase` and `device-reset` using `focus-send`
That being done, I’m stuck and the keyboard is still half working.
Just for context, I’m using Linux.
Any help is much appreciated.
Finally I found a solution to the issue in this issue on chrysallis. It seems something broke quite bad the firmware of atreus after 0.92
That said, I think that it could be great to have a better understanding of what happened.
