I thought I’d run into the stuck/repeating key issue, but then it got a bit weird…
Yesterday my backspace key started behaving weirdly. It would respond when pressed, but it was unpredictable whether it would remove 1 character, a couple, or keep going for several seconds. And it would trigger randomly even if I hadn’t pressed it for a while.
I tried the “Alcohol cleaning” solution. No change - still doesn’t respond.
Busted key, right? I gave up, with the intention of emailing support. In the meantime I disabled that key via Chrysalis and bound backspace to another key, only to discover that ANY physical key, bound to backspace, repeats until another key is pressed. (specifically, I’ve tried the actual “any” key, and the “cmd” key)
I flashed the “Chrysalis 0.7.9+282 default” firmware. Stalker LED mode indicated that the Backspace key is permanently pressed. However the problem of other physical keys repeating when bound to Backspace has disappeared.
Thinking about it, the repeating-key issue is a problem I’ve had before with the left shift key. Also solved by reflashing.
Thanks for the reminder! That was what led me to re-flash in the first place (I had apparently removed test mode in my custom firmware).
The result of test mode is… all keys work normally. WTF?
I tried to re-bind the backspace key for further testing, but now Chrysalis refuses to connect OR flash so I have a bit of manual tinkering to do.
Excellent point, thanks. I could have sworn Chrysalis auto-updated but it seems I was wrong.
I updated but - as above - it now refuses to connect OR flash. It is detecting the keyboard at least.
It turned out that a reboot fixed the connection/flashing issue.
I re-bound the physical key back to backspace, and… it worked fine. Literally nothing has changed (except unbind/rebind, and the Chrysalis version)
Problem solved, I guess? I’m wary that it’s a sign on the key being on its way out.
An update 1 month later: the issue came back. Reflashing did nothing this time (not that I’ve touched the firmware in the meantime). At least the weird key-jumping thing isn’t happening this time.
Currently looking into switch options here in Aus as shipping 10 from the US works out about the same price as buying a full set locally. Keen for suggestions (I’ve got the default Quiet switches)
