It seems like hardly anyone is talking about programming anymore, but I am doing some lately. I tried using algernon’s implementation of Syster plugin lately. It’s worked for me in the past but I didn’t really use it so I got rid of it. I’ve changed my workflow lately and I’m going to use it again, but with some changes because it only partially working for me. It behaves really weirdly.
Here’s (part of) algernon’s code:
/* -- mode: c++ --
- Model01-Sketch – algernon’s Model01 Sketch
- Copyright (C) 2016, 2017, 2019 Gergely Nagy
- This program is free software: you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation, either version 3 of the License, or
- (at your option) any later version.
- This program is distributed in the hope that it will be useful,
- but WITHOUT ANY WARRANTY; without even the implied warranty of
- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- GNU General Public License for more details.
- You should have received a copy of the GNU General Public License
- along with this program. If not, see http://www.gnu.org/licenses/.
#include “SymUnI.h”
#include <Kaleidoscope.h>
#include <Kaleidoscope-Unicode.h>
namespace algernon {
namespace SymUnI {
static const struct {
const char *symbol;
uint32_t code;
} symbol_map[] PROGMEM = {
{“coffee”, 0x2615},
{“lambda”, 0x03bb},
{“poop”, 0x1f4a9},
{“rofl”, 0x1f923},
{“kiss”, 0x1f619},
{“snowman”, 0x2603},
{“heart”, 0x2764},
{“bolt”, 0x26a1},
{“pi”, 0x03c0},
{“mouse”, 0x1f401},
{“micro”, 0x00b5},
{“tm”, 0x2122},
{“family”, 0x1f46a},
{“child”, 0x1f476},
{“ok”, 0x2713},
{“joy”, 0x1F602},
void input(const char *symbol) {
uint32_t code = 0;
for (uint8_t i = 0; i < sizeof(symbol_map) / sizeof(symbol_map[0]); i++) {
const char *map_symbol = (const char *)pgm_read_word(&symbol_map[i].symbol);
if (strcmp(symbol, map_symbol) == 0) {
code = pgm_read_dword(&symbol_map[i].code);
if (code)
Unicode.type(code);
else
typeString(symbol);
void typeString(const char *str) {
Unicode.start();
for (uint8_t i = 0; str[i]; i++) {
const char c = str[i];
Key key = Key_NoKey;
switch (c) {
case 'a' ... 'z':
key.setKeyCode(Key_A.getKeyCode() + (c - 'a'));
case 'A' ... 'Z':
key.setKeyCode(Key_A.getKeyCode() + (c - 'A'));
case '1' ... '9':
key.setKeyCode(Key_1.getKeyCode() + (c - '1'));
case '0':
key.setKeyCode(Key_0.getKeyCode());
Unicode.input();
handleKeyswitchEvent(key, UnknownKeyswitchLocation, IS_PRESSED | INJECTED);
Keyboard.sendReport();
Unicode.input();
handleKeyswitchEvent(key, UnknownKeyswitchLocation, WAS_PRESSED | INJECTED);
Unicode.end();
So the way it works is that if you type a symbol that is in the table it will delete what you typed and replace it with the corresponding symbol. If you type something that is not in the table it will treat what you typed as a hex unicode.
This is the problem. When I type any code that has a zero it, it won’t work. So for the coffee symbol, I can type “coffee” or “2615” (see table) and get the coffee symbol. But for lambda, I can type “lambda” and it will work, but if I type “03bb”, which has a zero in it, it doesn’t type anything. It seems very strange. I did come up with a workaround which works ok for me and which I like:
/* -- mode: c++ --
- Modifications Copyright (C) 2021 Stephen Polson
#include “SymUnI.h”
#include <Kaleidoscope-Macros.h>
namespace zerchi {
namespace SymUnI {
const char *symbol;
uint32_t code;
{“coffee”, 0x2615},
{“lambda”, 0x03bb},
{“poop”, 0x1f4a9},
{“rofl”, 0x1f923},
{“kiss”, 0x1f619},
{“heart”, 0x2764},
{“bolt”, 0x26a1},
{“pi”, 0x03c0},
{“mouse”, 0x1f401},
{“micro”, 0x00b5},
{“tm”, 0x2122},
{“child”, 0x1f476},
{“ok”, 0x2713},
{“joy”, 0x1F602},
uint32_t code = 0;
}// if
}// for
// If no match from symbol map, treat symbol as a four-character unicode and compute hex code from it.
if (!code) {
for(uint8_t i = 0; i < 4; i++) {
const char c = symbol[i];
switch (c) {
case ‘a’ … ‘f’:
// use bitwise OR to load up variable ‘code’ with 4 hexadigits
code = code | (0xa + (c - ‘a’)) << (12 - 4 * i);
case ‘A’ … ‘F’:
code = code | (0xa + (c - ‘A’)) << (12 - 4 * i);
case ‘1’ … ‘9’:
code = code | (0x1 + (c - ‘1’)) << (12 - 4 * i);
default:
// Do nothing. We are treating hex zero itself as well as anything other than
// a proper hexadigit as zero.
} // switch (c)
} // for
}// if (!code)
Unicode.type(code);
}// input()
}// namespace SymUnI
}// namespace zerchi
