Can you use the model100 octopus stand on the model 0?
I bought a model 01 second-hand which doesn’t have a stand. Was wondering if I buy the model 100 stand if it fits
Yes, the stands both use the same screw :slight_smile:
I have both models, and I use a model 100 with my model 01 octofeet as my home driver, and my model 01 with the octofeet from model 100 as my work driver. There is a reason for that: I had to modify the model 01 feet to work on my desk, and I did not feel like disassembling another set of feet to do the same when the new one came. No issues whatsoever. Only difference is the absence of orientation markings on the bottom of the old version.
