Hello, the “angled” (as opposed to the flat) bracket that the two halves of my Model 01 slot into has cracked - is it possible to either source a replacement, or get a file that I can 3D-print? Also one of the screwed-on-from-the-inside “feet” that slides into the bracket has snapped off, so I’d be looking to replace that as well. Thanks!
Hi John,
It’s not what you’re asking for, but these (Model 100…) stands may keep you typing while on the lookout.
Hey, thanks very much for the link. I might have to suck it up and try to model my own replacement parts…
