I’m a big fan of linear switches for typing. I was a little disappointed when the Model 100 came with these … colorfully named switches (seriously, "BOX Ocean Whale Silent Linear? lol) instead of the BOX Reds found in the Atreus, but I was happy to give them a try.
One of my frequent thumb keys came squeaky out of the box, but swapping it out was no problem. Other than that, I’ve really enjoyed them—more, even, than the reds.
However …
Maybe I got a bad batch, but it seems as though the reliability is lower on these than the reds. Multiple keys are now doing the squeaky routine. It’s a sort of squeak followed by a faint click, even though there’s no discernible tactitlity to using the switch. Now, I don’t hate clicky switches, but I do hate inconsistency. I unfortunately found it annoying enough that I boxed up my Model 100 for now (in favor of my Model F; like I said, I’m not a hater of clicky switches).
So the feedback is: They’re great switches … albeit inconsistent ones. I’ll probably swap them out for reds in the future and resume using my Model 100. (Question: Why were these chosen instead of reds?)
For reference: I’m a developer by profession and have been using the Model 100 as a daily driver since I got it. My work machine is also my home machine, so it sees > 8 hours of use each day. If you type less than me, you may go a long while without developing the problem (assuming my experience is typical). If you type more than me, then I’m sure you can extrapolate ![]()
