I’m wondering what people’s experiences are like with resting your palms while typing. How often do you press fn by accident? And do you think a version without the fn key would be better?
I don’t have that problem. I find I mostly rest my palms to the left or right side of the Fn Key and then sort of lean into it as needed.
I really like the Fn key and found it very easy to get used to
