Help with Uploading from Arduino
I’m very interested in getting Qukeys or something like that, so I have followed the online instructions to upload the stock firmware from arduino. I am on a windows 7 machine.
In Arduino, I have the following thing I see:
  • Tools --> Board: “Keyboardio Model: 01”
  • Tools --> Port: “COM5 (Keyboardio Model 01)”
When I compile, there is no problem, however, when I go to upload, I get the following errors:
 Arduino: 1.8.8 (Windows 7), Board: "Keyboardio Model 01"
WARNING: Category 'Debug' in library Kaleidoscope-Hardware-Virtual is not valid. Setting to 'Uncategorized'
Sketch uses 24770 bytes (86%) of program storage space. Maximum is 28672 bytes.
Global variables use 1407 bytes (54%) of dynamic memory, leaving 1153 bytes for local variables. Maximum is 2560 bytes.
Forcing reset using 1200bps open/close on port COM5
PORTS {COM1, COM5, } / {COM1, COM5, } => {}
Uploading using selected port: COM5
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -PCOM5 -b57600 -D -Uflash:w:C:\Users\Admin\AppData\Local\Temp\arduino_build_614114/Model01-Firmware-test.ino.hex:i
avrdude: Version 6.3-20171130
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM5
avrdude: ser_open(): can't open device "\\.\COM5": The system cannot find the file specified.
avrdude done.  Thank you.
What should I do?
Thanks!
Did I post the wrong info? Should I ask in a different forum?
Thanks!
