How to change keycaps
Santa has graced me with Blank Keycaps for my Model 01 (Translucent Keycaps for the Model 01 – Keyboardio). Awesome!
There is just one thing; there is no documentation, so how do I actually switch out the old keycaps with these new ones?
I also just got translucent keycaps for the Model01 :slight_smile: You just need to pry them off / pull them up off the switches - I usually start with one of the edge keys like the LED or Any key, then it provides easier access to the rest.
Yes, and if by mistake you scramble all the set, there are numbers on the back of the keys to reassemble them in the good order, and in the right orientation :smile:
