I’ve built an arduino HID relay by following this video:
When I plug in a vanilla usb keyboard (i.e., not the Atreus) and run this keyboard example, I do see the key presses in the arduino’s serial monitor:
However, when I plug in the Atreus, none of the keys register.
I suspect the problem is that the Atreus is incompatible with the spi4teensy3 library being used by the arduino sketch, but even if that is the case, I.m not sure what I would need to change to get it to work.
Are there any documents or guides which would be helpful for debugging?
