Instant bespoke dust covers
I don’t know if anyone did this before. I first used a cloth to cover my k keyboardio, but one day I had this idea: I removed the top foam pieces from the original box (which wasn’t hard at all since they were fixed with double sided tape), and, voilá: perfect fitting dust covers. Here’s what it looks like:
Hope you like the idea, cheers!
Yup, great idea. If the packing is well made (moulded), I often use the packaging as dust covers. I do exactly the same for my Ergodox EZ, Logitech M570 trackball and Filco keyboard. The packaging makes perfect dust covers. :smiley: And in all my examples, the packaging was clear plastic, so doesn’t look bad at all, because you still see the device underneath it.
