Issue with non-responsive ctrl key on loud-click keyboard
I have a clicky keyboard that initially suffered from the dreaded key chatter. Cleaning the switch with isopropyl alcohol a couple of times fixed the problem and it’s been fine for months.
Now, the same key struggles to respond to key presses and I have to consciously hold it down for it to register. Does anyone have any suggestions or should I try and replace the switch?
If alcohol isn’t helping, one (no-warranty-supported) option may be opening the switch to clean it.
Note that we strongly recommend -not- bending either of the electrical contacts inside Matias switches.
I also have an issue where the left Ctrl key just stopped registering. I’ll also see about cleaning.
