Unwanted keystrokes registered on model 100 and Atreus
Hi all,
I just received my new model 100. I am having the same issue that I had with my Atreus. There is something wrong with the keystrokes. I have installed the latest firmware 0.90.2+44
Sometimes there is a significant delay (1-2 seconds) between pressing the key and being typed in the computer, so there may be a word or two that I type that takes a while to appear registered on the screen. It feels like it is being buffered and then all keystrokes are sent at once.
Sometimes also the keystroke is repeated indefinitely, so I have to press other keys to stop sending it the same letter to the computerrrrrrrrrrrrrrrrrrrrrr. :frowning:
I do not think it is a switch. It happens even when I am writing on a logitech keyboard (with the model 100 still plugged). This behaviour stops as soon as I unplug the model 100.
So I think that there is something going on with the PC & model 100. My guess is it has something to do with my Windows 10 machine settings. I was wondering if someone have any hints on how to debug this problem.
Many Thanks!
Alex
no solution, but I have experienced similar problems with Model 100 with Windows 10 (not so far with Windows 11, which I use mostly nowadays) and with the current firmware as well, which is for me 0.91.0+68.
When my keyboard went crazy I could not stopppppppppppppppppppp the key by pressing another key, but had to unplug the keyboard.
That is also my experience. Same keyboard behaves differently in windows and linux. No problem in linux at all.
