I bought an Atreus a while back, and I still can’t seem to get it set up. I’m running mac iOS Tahoe 26.3 (25D125). When I plug it into the computer doesn’t even recognize it (I’ve tried several different computers). I use a Model001 with no issues. Can someone point me to where I can find the setup instructions or a driver I might need? The member I bought it from said they used it with a PC. Does that make a difference?
I use mine with a Mac (Sequoia) and haven’t experienced any issues. I also swap it between the Mac and a Linux computer. There shouldn’t be any need for a driver, afaik.
It didn’t come with one, and perhaps the one I’m using is not the right type. I’ll go have a look at the specks. The one I tried was plugged into the keyboard I was using at the time.
