I’ve encountered a bug with my Atreus. If you hold down LShift, then hold RShift, then release LShift, the next character you type will be lowercase instead of uppercase. I actually encounter this bug fairly often, as I tend to swap which shift key I’m using depending on which side of the keyboard the desired letter is on.
I’d have posted it as an issue on Github, but I’m not 100% on which repo it should go in.
I tried this on my new Atreus, switching multiple times always holding down a shift key and could not duplicate this. HE ON TESTINGO I’m using Dvorak, but I don’t think that should matter.
