Chrysalis blank page when keyboard connected
Hi all,
In the initial page the keyboard is detected, but when I press connect the only thing I get is a blank page. I have downloaded the lasted version and installed in two different computers running MacOS Catalina. In both computers the behaviour is the same. The keyboard works fine. I flashed this keyboard in the past with the Arduino IDE.
Any idea?
Cheers!
Arnau
Can you open the developer console (Cmd+Shift+I, or going into Preferences before connecting, you can turn it on under the Advanced settings), and see if there are any errors there? A paste or screenshot of that would be most appreciated.
Here you are
Thanks! This will help narrow things down.
I have been downgrading up to 0.6.2 without any luck. Below you have the error I get in that version. I don’t know if will help.
Arnau
