Chrysalis Error After Upgrading to Ubuntu 20.04.1 LTS
I recently freshly installed Ubuntu 20.04.1 LTS over my old Ubuntu 18 system. Now Chrysalis seems to be giving me an error when I try to run it. Has anyone else come across this?
$ ./Chrysalis-0.7.9.AppImage
../../sandbox/linux/seccomp-bpf-helpers/sigsys_handlers.cc:**CRASHING**:seccomp-bpf failure in syscall 0230
(node:199331) Electron: Loading non context-aware native modules in the renderer process is deprecated and will stop working at some point in the future, please see https://github.com/electron/electron/issues/18397 for more information
-rwxrwxrwx 1 USER USER 83133476 Aug 10 13:51 Chrysalis-0.7.9.AppImage*
*I added myself to the dialout group to see if that would help and it didn’t.
Chrysalis does load but displays the following message:
Insufficient permissions, please make sure the device file is read- and writeable!
It seems I may have had to restart my computer for Ubuntu to register my addition to dialout.
Chrysalis now runs properly and does not display the “Insufficient permissions” error message, but I still get the terminal errors.
Restarting a computer is a Microsoft User’s strange habit… With Ubuntu (and mostly all unix related systems (GNU/Linux, BSD, …), you just have to reload your session for the changes to be applied :slight_smile:
While doing this fixed the chrysalis error, it broke networking for me on Ubuntu 19.10
 $ sudo adduser $(whoami) dialout
To undo this, I did
$ sudo gpasswd -d $(whoami) dialout
Sorry if this is obvious to you, but what did I do wrong?
Hi, everyone. Just for the record, I’m using Manjaro, and the group to add the user to in order for Chrysalis to work is “uucp”.
(and yes, just logout and login to the session will work ok for changes to take effect)
